Latency on BNGs vs older gateways
AndyH
Is anyone else seeing higher latency on the BNGs compared to the older gateways?
ptw-ag02
--- bbc.co.uk ping statistics ---
100 packets transmitted, 100 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 4.346/4.616/4.906/0.116 ms
ptn-bng01
round-trip min/avg/max/stddev = 7.632/8.039/21.294/1.335 ms
I know I have a low ping response times generally and a few ms doesn't make a difference - but I am interesting if anyone on FTTC/ADSL sees the same.
I'm aware that our traffic can take different routes through the BT Wholesale 21CN network which will affect latency, but I can never get the same low ping times on the BNGs as I can on the older gateways.
52 REPLIES 52
Gus
Re: Latency on BNGs vs older gateways
On DSL nope, currently at my normal 40ms on ptw-bng01
FTTP 500 regrade from Tues 28th November
AndyH
Are you on 21CN or 20CN?
Gus
21CN, but one thing I have noticed with them and some other gateways, is that my TBB graph usually looks worse than it is, e.g. lots of  yellow maximum/blue average ping spikes when watching streams.
SpendLessTime
Fixes: 86
Andy
I'm on ptw-bng01 currently and seeing no difference to other gateways for ping times. BQM is seeing more small red lines though.
Currently:-
    Packets: Sent = 100, Received = 100, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 4ms, Maximum = 5ms, Average = 4ms
rongtw
Fixes: 12
For some reason whan i am on BNG ,s my games dont play as well  Embarrassed
but its fine on the older gateways
goldenfibre
Seasoned Pro
Fixes: 12
Sorry but how to do ping test on CMD, I forget the command line
AndyH
ping bbc.co.uk
goldenfibre
Seasoned Pro
Fixes: 12
Pinging bbc.co.uk [212.58.244.18] with 32 bytes of data:
Reply from 212.58.244.18: bytes=32 time=12ms TTL=56
Reply from 212.58.244.18: bytes=32 time=11ms TTL=56
Ping statistics for 212.58.244.18:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Minimum = 11ms, Maximum = 12ms, Average = 11ms
That's was on gateway ptn-bng01
On Linux, I tend to use 'mtr' rather than 'ping', because it gives you a bit more detail about where the delays are -
$ mtr -r -c 10 plus.net
HOST: My_Laptop                  Loss%  Snt  Last  Avg  Best  Wrst StDev
  1. My_Router                    0.0%    10    0.6  1.4  0.6  3.5  0.9
  2. lo0-central10.ptn-ag01.plus.  0.0%    10  28.6  29.9  28.6  33.6  1.5
  3. link-a-central10.ptn-gw01.pl  0.0%    10  28.9  29.5  28.9  31.0  0.7
  4. xe-5-2-0.ptw-cr01.plus.net    0.0%    10  29.5  29.5  28.4  32.7  1.4
  5. ae1.pcl-cr01.plus.net        0.0%    10  29.3  29.1  28.2  30.1  0.7
  6. po2.pcl-gw01.plus.net        0.0%    10  29.2  29.5  28.8  31.1  0.7
  7. gi5-8.ptp-cr01.plus.net      0.0%    10  36.4  37.0  35.8  40.8  1.4
  8. vlan2658.ptp-elb02.plus.net  0.0%    10  37.0  37.5  36.3  38.8  0.9
  9. portal.plus.net              0.0%    10  38.2  38.4  36.8  41.0  1.2
For further reading - Wikipedia : MTR
Wink
Dhaos
I always find i get a max of 68Mb on the bng's compared to 72Mb on the older ones. But my latency doesnt seem to change.
AndyH
@ georgelnx - How strange. My average latency on any BNG is double what it is on the older gateways. I can tell which gateway I am on based on the ping times.
@ rongtw - Do you have increased latency on the BNGs compared to the older ones?
@ purleigh - Do you notice any difference in the latency on the BNGs?
goldenfibre
Seasoned Pro
Fixes: 12
ping plus.net
Pinging plus.net [212.159.9.2] with 32 bytes of data:
Reply from 212.159.9.2: bytes=32 time=21ms TTL=247
Reply from 212.159.9.2: bytes=32 time=19ms TTL=247
Ping statistics for 212.159.9.2:
    Minimum = 19ms, Maximum = 21ms, Average = 19ms
Quote from: AndyH
I haven't bothered trying the BNGs recently, so can't really comment.
I used to be an avid gateway hopper, when there were gateway problems and switching could make a big difference in latency and packet loss.
When we were first asked to try using the BNGs I did try them for a while, but generally found the PTNs better.
These days I try to hop onto a PTN and stay on there for months, and only tend to change gateways if a thunder storm has knocked me off.
So unless 'Kelly' or 'Dave' specifically ask for helpers to assess a particular gateway, then you will find me on a PTN.
Wink
goldenfibre
Seasoned Pro
Fixes: 12
The new gateway is little faster than the old gateway.
With PTNs - I getting 73.1Mb down
With BNGs - I getting 74.5Mb down
