Latency on BNGs vs older gateways
- Latency on BNGs vs older gateways
Re: Latency on BNGs vs older gateways
07-08-2014 2:50 PM
Yes it is against bbc.co.uk
I used the windows command
"ping -f -l 1464 -n 100 bbc.co.uk"
where -l (lower-case L) is the packet size (maximum size -28 bytes overhead), -f means that the packets cannot be split in size and -n is the number of times to ping the site.
07-08-2014 2:50 PM
07-08-2014 2:54 PM
Packets: Sent = 100, Received = 100, Lost = 0 (0% loss)
Approximate round trip times in milli-seconds:
Minimum = 12ms, Maximum = 13ms, Average = 12ms
After testing with ping -f -l 1464 -n 100 bbc.co.uk and gateway are: gateway ptn-bng01
07-08-2014 3:10 PM
07-08-2014 3:34 PM
You are currently connected to gateway ptw-bng01.
This is located in Telehouse West.
But speed is the worse ever below:
Testing ping below:
Ping statistics for 212.58.244.18:
Minimum = 11ms, Maximum = 15ms, Average = 11ms
I wish I never change gateway as it was 74/18 but now struggle at unbelieved slow 43/18
07-08-2014 4:20 PM
You are currently connected to gateway pcl-ag05.
This is located in City Lifeline House.
and speed is much better now at 73/18
ping test result:
AndyH I did test with same gateway as George but getting higher ping than George but very slow speed.
I think it problem with BT route gateway, some speed are terrible slow. But, I am now on the different gateway and speed back to normal as it should be but can't do anything about ping remain at 12ms
07-08-2014 9:03 PM
And your experience is why once I'm on a reasonable gateway, I don't like to manually hop.
However the hop to ptw-bng01 was forced by Openreach when they did some work on the exchange on July 30th. I've suffered by hopping gateways in the past in an attempt to get speedtest/thinkbroadband to be a consistent 76Mbps. Currently speeds are 76Mbps ( or 78Mbps on BTW test) and ping times reasonable so I'm staying put.
George
07-08-2014 9:54 PM
08-08-2014 3:26 PM
There are a lot more moving pieces involved than just an exchange/product/gateway to get a good consistent speed/response times.
I've have had some horrendous speed/latency issues on a supposedly "it works or doesn't work" fttp line. This proves how complicated things are in broadband these days.
When I was getting 500Kbps down for 18 hours plus at a time, people on the boards said that it wasn't possible as fttp works or doesn't. Rubbish, just shows that even the perfect product (if you read other peoples' comments) will have issues which are hard to pin down. When this was happening Andy had zero issues for the nearly 4 months it took to solve. Turned out to be faulty equipment in the exchange but not faulty enough for the monitoring to spot!
I don't have an answer for you goldenfibre, just that some times it doesn't pay to be helpful and hop gateways. Done that myself in the past and regretted it too.
I do think that we need to raise these latency issues when we see them as it may one day help Plusnet/Openreach find out why we are getting the problems but as they effect people at random (not the whole 40k plus on that gateway) it may be a long wait.
George
08-08-2014 3:30 PM
Ex-Broadband Service Manager
08-08-2014 3:34 PM
I'll stay connected to the same gateway unless something kicks me off.
08-08-2014 3:47 PM
08-08-2014 4:00 PM
08-08-2014 4:07 PM
08-08-2014 4:17 PM
