Latency on BNGs vs older gateways
- Latency on BNGs vs older gateways
Re: Latency on BNGs vs older gateways
06-08-2014 6:13 PM
I find the BNGs give me slightly better throughput but the latency is higher.
I have only been trying low response sites like bbc.co.uk, so I will try some others to see if they are comparable with different gateways.
I am a little baffled about how George gets 4ms on a BNG. We're on the same product on the same exchange - so we should be able to get the same, I would have thought.
06-08-2014 6:15 PM
Ask George to do another ping test here!
@ AndyH I don't understand why old gateway lower throughput than the new gateway?
06-08-2014 6:23 PM
Quote from: AndyH @ purleigh - I see what you're saying
I don't think I would notice a gateway throughput difference on my 6.7Mbps ADSL1 20CN line
I'll stick with the lower latency PTN
06-08-2014 6:53 PM
Quote from: AndyH I am a little baffled about how George gets 4ms on a BNG. We're on the same product on the same exchange - so we should be able to get the same, I would have thought.
Share your postcodes? It could well be a difference in backhaul back to the datacentres.
Ex-Broadband Service Manager
06-08-2014 7:11 PM
as i have said here before I regularly swap gateways to find one where i get a good game connection which also seams to depend on time of day
i sometimes find a gateway which for me plays well for several days but then for some reason it deteriorates so i just hop to the next gateway
06-08-2014 7:34 PM
I'm MK15 and George is MK5 something (I think). We only live a few miles apart.
As I said to Paul ages ago, this is not a problem for me but it's worth looking at in case it affects people. I assume it's the way the traffic comes through the BT Wholesale network.
06-08-2014 8:15 PM
Pinging bbc.co.uk [212.58.244.20] with 32 bytes of data:
Reply from 212.58.244.20: bytes=32 time=15ms TTL=56
Reply from 212.58.244.20: bytes=32 time=14ms TTL=56
Reply from 212.58.244.20: bytes=32 time=13ms TTL=56
Ping statistics for 212.58.244.20:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 13ms, Maximum = 15ms, Average = 14ms
You are currently connected to gateway ptw-bng01.
This is located in Telehouse West.
Taken at 20:10 via FTTC (40MB)
06-08-2014 9:15 PM
In general though, all the other BNG gateways are 1-2ms higher for me. As you say, not much, but higher.
06-08-2014 11:50 PM
07-08-2014 1:27 PM
MK7
@goldenfibre
current ping is
Packets: Sent = 100, Received = 100, Lost = 0 (0% loss),
Minimum = 4ms, Maximum = 5ms, Average = 4ms
@AndyH
When I had my 4 month long speed issues, you were not affected in the slightest. During that time I had my line moved between VLANs and the line card in the exchange replaced. So yes same product (FTTP) but not necessarily the same configurations.
George
07-08-2014 2:33 PM
Edited: I found it now... cmd /k ping bbc.co.uk /n 100
07-08-2014 2:40 PM
Minimum = 11ms, Maximum = 12ms, Average = 11ms
@ George did u test it via bbc.co.uk?
07-08-2014 2:41 PM
07-08-2014 2:43 PM
07-08-2014 2:48 PM
I'm on the same gateway as George now, but my ping times are high (4-5ms to bbc.co.uk). I'm assuming that this is all down to the BT routing.
