Just wondering - Overnight usage question.
- Re: Just wondering - Overnight usage question.
01-06-2012 12:04 AM
Thanks guys
01-06-2012 12:42 AM
Which is when the unlimited overnight starts, unthrottled. The same clock.
My little download speed graph on my menu bar went from a line to a block at midnight.
(Note, Speedtest results are the same 24 hours per day, download speed as reported by BBC iPlayer shoots up at midnight, throttled by PN, 6pm to midnight, on my package)
01-06-2012 8:23 AM
01-06-2012 8:31 AM
How it should work is that Plusnet get usage reports at intervals (I think every 30 minutes) and any usage where there is doubt as to whether it is paid or free is discarded (or perhaps reported as free). The idea being that the customer isn't incorrectly charged for usage just inside the free period
01-06-2012 10:32 AM
01-06-2012 10:53 AM
On the subject of overnight usage there has been a issue for a while that if you download a decent amount overnight this isn't recorded. Almost as if the usage rolls back to zero after a certain amount.
James
01-06-2012 11:14 AM
dick:quote
01-06-2012 11:18 AM
No it doesn't affecting my billing as overnight is free. I have pondered at times if the issue issue exists during on peak times but have never fancied risking a decent amount of my usage allowance testing!
I'm sure I have see the same issue mentioned by other people on this forum in the past. I just mentioned it as does mean the recorded usage is incorrect, albeit from a practical point of view it doesn't matter.
James
01-06-2012 11:32 AM
Quote from: PlusComUK Midnight exactly, as just demonstrated by my downloading BBC iPlayer at low speed, 11:45pm, which shot up to 17mb/s at midnight, as it does every night.
Quote from: Oldjim Despite what was said above - overnight usage is nothing to do with the speed throttling.
Please note what I said about the clock Jim.
The BBC iPlayer speed is an indication of the PN clock, and it shifted up 5 gears dead on midnight.
Quote from: JEB
James
I downloaded 14GB this morning between midnight last night and 8am this morning, and it was recorded !
01-06-2012 11:36 AM
01-06-2012 11:38 AM
01-06-2012 12:00 PM
01-06-2012 1:54 PM
Quote I downloaded 14GB this morning between midnight last night and 8am this morning, and it was recorded !
I have never quite worked out exactly much you need to download before the usage goes wrong but it is a decent amount, say over 20GB but I'm not sure how much over.
jim:green quote fixed mod:end
03-06-2012 1:13 AM
03-06-2012 5:35 AM
