Errors In The Router
- Errors In The Router
29-05-2012 5:50 PM
Re: Errors In The Router
29-05-2012 6:04 PM
29-05-2012 6:11 PM
29-05-2012 6:14 PM
29-05-2012 6:17 PM
29-05-2012 6:22 PM
if you want to understand more about what is happening I suggest reading that page more closely and also the other technical pages on that site which is a very useful source of information
29-05-2012 6:24 PM
29-05-2012 6:41 PM
29-05-2012 6:43 PM
Loss of Link (Remote): -
Error Seconds (Local/Remote): 2.190 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 31.353
HEC Errors (Up/Down): 0 / 8.024
29-05-2012 7:10 PM
That is a Technicolor 582n you are using is it, can you say what firmware version you've got?
I've never like the error stats reporting on recent Thomsons, the results you've just posted seem to have decimal points in, so if the number is otherwise right ie 31 CRC errors that seems reasonable. If it should have been a comma ie 31,353 CRC errors OMG.
I don't have a 582n myself to play with. Personally I think it's a firmware bug, which is why I'm asking about the version
29-05-2012 7:20 PM
Uptime: 0 days, 2:17:56
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1.215 / 20.927
Data Transferred (Sent/Received) [MB/MB]: 119,14 / 445,73
Output Power (Up/Down) [dBm]: 12,2 / 0,0
Line Attenuation (Up/Down) [dB]: 7,2 / 15,5
SN Margin (Up/Down) [dB]: 6,5 / 6,1
Error Seconds (Local/Remote): 2.418 / 0
CRC Errors (Up/Down): 0 / 33.298
HEC Errors (Up/Down): 0 / 8.414
And yeah it is the plusnet router i am using the technicolor tg582n with software release 8.4.4.J
29-05-2012 9:24 PM
30-05-2012 2:25 AM
30-05-2012 8:30 AM
30-05-2012 10:28 AM
Pinging www.bbc.net.uk [212.58.244.70] with 32 bytes of data:
Reply from 212.58.244.70: bytes=32 time=40ms TTL=55
Reply from 212.58.244.70: bytes=32 time=37ms TTL=55
Reply from 212.58.244.70: bytes=32 time=34ms TTL=55
Reply from 212.58.244.70: bytes=32 time=42ms TTL=55
