Just got fibre, not impressed with the router
- Re: Just got fibre, not impressed with the router
26-03-2012 12:02 PM
Hi, i have recently upgraded to fibre and am very happy with the speed, however i am not very happy with the supplied router, it is only 2.4 Ghz and only 150M/s Wireless N. the router it replaced was a dual band and 300Mb/s, so i would like to know what other routers am i able to use. I would also like to run a VPN through PPTP, my router at the moment connects to Plusnet using PPOE using my credentials, could i just change to PPTP and use the credentials of my VPN provider?.
Any help would be appreciated
Message 1 of 5
(6,177 Views)
4 REPLIES 4
26-03-2012 12:13 PM
As I understand it you can use any router that supports PPOE, but you want one with Gigabit ports, then you can be pretty sure it will be able to handle the through put of the fibre connection.
Message 2 of 5
(752 Views)
26-03-2012 2:22 PM
Yes i have a router that i would like to use, it has DD-WRT firmware installed and i was wondering can i just enter the details of my VPN account in the username and password fields of the PPTP setup or must i use the username and password given to me by plusnet. and use PPOE, again any help will be appreciated(the basic setup page has a drop down which has PPTP and PPOE options on)
Message 3 of 5
(752 Views)
26-03-2012 4:34 PM
The router uses PPOE to tell the BT Fibre modem your plus net username and password login details , I'm not sure about the VPN details, but I would at a guess say they have nothing to do with your plus net login, and would be entered elsewhere.
Perhaps have a read of this http://www.dd-wrt.com/wiki/index.php/Static_PPTP_VPN_Client
Message 4 of 5
(752 Views)
06-04-2012 10:13 AM
thanks for the help, I will definitely be ditching the supplied router and getting a different one
Message 5 of 5
(752 Views)
