Is my download speed capped?
simmotech
Last Friday we had an area power cut and while testing everything was working when the power came back, I noticed my broadband speeds had actually increased and not by a little but 40%!
Speedtest.net normally shows 48/16 consistently but for 3 days it showed 68/18.
However, after another powercut on Sunday evening, everything went back to 48/16.
Boo!
So my question is if my line/line length is capable of 68mbit why am I not getting that?
11 REPLIES 11
Fixes: 334
Re: Is my download speed capped?
@simmotech What does this say BT Broadband ? - post the full text, but obscure your phone number.
simmotech
I don’t have a phone number and don’t know where to find the other info. I’ll try to find it on Plusnet.
Fixes: 334
So, you are on SoGEA? Use this instead, then, selecting your address - but obscuring it in the reply: BT Broadband - Address
Fixes: 526
@simmotech just use the Address checker. Enter your postcode and then select your address from the dropdown list
simmotech
The Plusnet website and especially the help assistant are so [-Censored-]!
Anyway, I found the BT Address checker and here is the result:
This seems to indicate I should be getting more than I am!
(Also it says FTTP on Demand Availability Date is "Available" but further down says "FTTP is not Available" - [-Censored-]?)
The Plusnet website contradicts itself:
- My current product is "Unlimited Fibre Extra inc. Line rental" with an Estimated download speed of 42-47Mbps and 38Mbps guaranteed.
- The Offers and Upgrades tab says my current product has 66Mb estimated download speed yet offers me a "Fibre" 24 month upgrade contract (£23.99/m vs the £28.59 I current pay) at 42-47Mb and 38.1 Min guaranteed speed
- I just looked back at my joining email from 26/08/22 where it says it estimates 49-67Mb with 12-18Mb Upload and a Minimum guaranteed Speed of 42.MB.
Fixes: 334
FTTP on Demand and WBC FTTP are two totally different products - and you don't even want to look at the costs for the former!
Which Hub do you have?
simmotech
Its a Plusnet Hub Two DSL
Fixes: 334
OK. Can you do as asked in the below script - preferably on a full sized screen so we can see full details.
BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS'. This test is recommended to be performed with only one device connected.
For the Hub One -
For the Hub Two -
simmotech
I’m not near my PC now to get full screenshots but I’ve looked at the hub event log on the phone and it clearly shows connecting at 73xxx kbps on a couple of occasions (9th and 10th Dec) followed by 52350 kbps on 11th Dec.
The difference is the SNR which is 1.9dB then 4.4dB and then 6.2dB.
Fixes: 334
When you can do the tests - from the PC - please do.
Fixes: 124
When you get a chance also export the event log after selecting category WAN and attach as a file, this will provide a full history for the DSL connection.
Dan
