Broadband Regularly Dropping
samueljstroud
Hi!
We switched over to Plusnet about a year ago, and all through that time, the broadband has regularly stopped working at random intervals.
But now, starting yesterday, it's switching between blue and orange almost every five minutes.
I've done all the tests that I can find online, but nothing seems to work.
I work from home, so these regular outages are having a massive impact on my work.
Any help is greatly appreciated!
8 REPLIES 8
Fixes: 344
Re: Broadband Regularly Dropping
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
NOTE: I shall ask for the duplicate post to be removed.
@samueljstroud wrote:
... starting yesterday, it's switching between blue and orange almost every five minutes.
Did you put Christmas decorations up yesterday ?
samueljstroud
Thanks for the quick reply!
Regarding the test, it's a phone line connection, but I don't have a phone.
Live in an area where we couldn't get the full fibre, so this is a compromise.
So I don't have a phone number for the test, awkwardly.
Fixes: 344
So report a network issue using the second link - it probably is one, anyway.
samueljstroud
Sorry I may not have been clear.
It seems that I can't proceed any further on either test without first inputting a phone number, however I don't have one to give.
Fixes: 344
If you are on an FTTC or ADSL connection, your phone number will be on your member centre pages somewhere - you can't have a connection without one.
samueljstroud
I've looked all through the papers I have, and there's no phone number anywhere?
Fixes: 344
Try logging into your account, and click the 'Manage Account' tab at the top - it should be on the resulting page.
