Intermittent very slow speeds
- Intermittent very slow speeds
Re: Intermittent very slow speeds
02-09-2009 6:43 PM
04-09-2009 8:50 AM
When I've plugged it in, will the same tests be run with the new hardware so that I can rule out the internal stuff and pretty much confirm the problem is from the master socket outwards?
04-09-2009 8:59 AM
Let me know when you've got the router and see if it behaves better than the plusnet netgear one.
04-09-2009 10:21 AM
04-09-2009 10:24 AM
It's basically a loss in signal from your router to the BT exchange, causing the connection to drop.
04-09-2009 10:54 AM
04-09-2009 10:56 AM
I generally don't do those ones though.
04-09-2009 10:59 AM
04-09-2009 2:17 PM
Got the router plugged in and setup. Everything now up to the router is from the box you sent me. Your filter, cable and router. Very happy with that since it should hopefully prove where the fault lies, inside or outside. Can you run the tests at some point to see if there is an improvement/fix? Is the plan of action to wait and see if an error re-occurs?
Pretty basic router but looks like it does what it says on the tin. I should probably have got a router when I joined PN but I deferred on it.
04-09-2009 2:34 PM
You're probably the best test we have currently - are you seeing an improvement?
04-09-2009 2:38 PM
I have noticed that the DNS lookup seems to be faster though. When I type in a url/click link/bookmark the page seems to be found faster. Loading seems the same though.
04-09-2009 5:36 PM
Link Information
Uptime: 0 days, 3:25:16
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,952
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 28.37
Output Power (Up/Down) [dBm]: 12.0 / 17.5
Line Attenuation (Up/Down) [dB]: 31.5 / 60.0
SN Margin (Up/Down) [dB]: 14.0 / 15.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 5,880
CRC Errors (Up/Down): 0 / 8
HEC Errors (Up/Down): 0 / 8
05-09-2009 8:54 PM
The DSL screen of the router says:
DSL Connection
Link Information
Uptime: 1 day, 6:41:43
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 220.63
FEC Errors (Up/Down): 0 / 15,484
CRC Errors (Up/Down): 0 / 32
HEC Errors (Up/Down): 0 / 29
So 1 day 6 hours up... but there's also an Internet screen and that says:
Internet
Connection Information
Uptime: 0 days, 0:28:30
Data Transferred (Sent/Received) [MB/MB]: 81.58 / 187.59
Username: *************
Password: ********
Remember Password: Yes
IP Address: ****************
Primary DNS: 212.159.6.9
Secondary DNS: 212.159.6.10
28 Minutes??? So which is right? Does that mean I'm still getting disconnects with this new router too?
06-09-2009 9:26 AM
06-09-2009 9:34 AM
