Intermittent very slow speeds
- Intermittent very slow speeds
Re: Intermittent very slow speeds
29-08-2009 3:49 PM
29-08-2009 4:06 PM
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 2048 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 135 kbps
Actual IP throughput achieved during the test was - 86 kbps
29-08-2009 4:22 PM
Quote ~ What is "Adaptive Max Logic"?
* Decreases in sync speed will still reflect in the IP profile within 75 mins.
* Increases in sync speed will depend on the percentage of the increase and will vary between a few hours and up to 5 days.
A large % increase in sync speed should see the IP profile rise within 4-6 hours, whilst a small increase may take up to 5 days before the IP profile reflects the change. BT estimates that under "Adaptive Max Logic" more than 60% of increases will now occur before they would on the old 3 day system.
Examples:-
1. - Large increase - Line dropped to a 576 sync during a thunderstorm (profile = 500), after a resync it went back up to 7616 (profile 6500). Profile increase = 6000/500 *100 = 1200% increase which should occur in 4-6 hours.
2. - Small increase - Sync increase from 7616 (profile 6500) to 8128 (profile 7150) after interleaving removed. Profile increase = 650/6500*100 = 10% which may not take effect for 5 days.
How long it exactly takes for increases to be applied would also seem to depend on how busy the system is.
So my router synced at about 190 or something and dropped my speed, but it is now back up at 2048, so that is 2048/135*100=1517% increase. So why do I have to wait 3 days? Why not 4-6 hours?
29-08-2009 4:53 PM
I have an idea: Maybe you could wait until your IP profile recovers and then switch off your router when you are not using the internet. If you get a low sync speed then you can resync it before it has had time to lower your IP profile. I haven't tried this but it might work.
Hopefully PN/BT will fix the underlying fault soon
29-08-2009 5:00 PM
29-08-2009 5:54 PM
29-08-2009 11:10 PM
Quote FRC change to DCN
What does that mean?
30-08-2009 7:30 AM
31-08-2009 9:40 PM
A borrowed router should remove that from the problem, then I just need to try to confirm that the cable and microfilter are sound. Is there any way I can do that well? I have two microfilters but I cannot know for sure that either really works.
31-08-2009 9:42 PM
Any idea what the acronyms mean? I get the DCN (disconnect) one. I'm just wondering if AA may help me with some idea of the likelyhood of the fault being mine or where it could be.
CLT & TAM still pass, DCN ongoing. Fault in AA
01-09-2009 9:03 AM
01-09-2009 9:18 AM
@ Jayed
Give me a bit of time to go through your fault and I'll see what's currently going on. It sounds like your fault is already with BT and I'll see what the current state of play is.
01-09-2009 9:19 AM
CLR & TAM are two different parts of the testing process.
We need to book an engineer appointment for you. If you haven't managed to try a different router on your line, let me know and I can arrange for one to be sent out on loan.
01-09-2009 5:50 PM
Is it a router/modem or just modem?
Oddly, I think BT have upped my profile today since it seems to be PN's restricting me right now.
And in bad news... My harddrive on my windows pc, which had been on for days monitoring the line, blew up this morning... sucks.
Thankfully they are pretty cheap now.
02-09-2009 10:55 AM
I've just replied to your ticket letting you know that I've ordered a loan router. It should be with you in a couple of days or so.
Good luck with the harddrive!
