Intermittent Internet Service
- Re: Intermittent Internet Service
06-05-2012 2:32 PM
The Connection Chart that Jojo posted a while back showed a definite pattern of these occurring in the morning, with only an odd one on 2 or 3 evenings at different times.
On the subject of the wireless, as you aren't using it can you turn it off, I'll send you PM.
06-05-2012 5:16 PM
RSL active from @0756hrs and still running
When I started RSL this morning we were 6 to 6.5 SNR for almost an hour.
@0817 Router re-synced down from 1056 to 960Kbps
@0843 big single step up to 8.5 SNR
@1345 big single step up to 11 SNR
@1605 For 15 mins a series of steps in quick succession bringing SNR down to what we are now at 6.5 (and now 'live' flirting with 6)
See 'compacted' RSL SNR data graph (can supply expanded with more detail if needed - Chris)
The jumps do seem to be sort of 'clean(ish) jumps'. @ Chris regarding our heating, this is still on constant from the winter! (I feel the cold). All day and night long it goes on and off all the time.....which would not correspond to the times of day when RSL shows the SNR flatlined (ie yesterday afternoon/evening). I have been round the house (literally) and there is nothing that has come on which even remotely corresponds to the graphed jumps. When the jump at @1345 happened....there was no-one at all at home.
Alex
06-05-2012 7:34 PM
there has been another SNR 'wibblewobble'
This graph slightly overlaps the previous , but you can clearly see the suden step up and down between approx 1849 and 1905hrs.
SNR was flat at 6.5 then up to 9.5 for these 15 mins then back to 6.5.
This latest peak is quite uniform though. The SNR wobbles a little bit before it rockets up then just after the SNR rockets back down the SNR again, wobbles a little bit. Can anything be interpreted from this?
Chris - I forgot to tell you that I collect electric 'stepper' motors and have numerous ones in the garage which I play with! This IS a joke!
Alex
06-05-2012 8:42 PM
Did you turn off the wireless?
06-05-2012 8:57 PM
Wireless off - yes
Most up to date RSL graph attatched.
back to a steady flat 6.5SNRM now!
07-05-2012 1:27 AM
Here is what your connection has been doing recently, as you requested.
07-05-2012 6:24 AM
I'll check again to see if I've overlooked anything and drop you another PM.
Edit: Do you recall if the pattern was similar with the Linksys modem/router - Note I'm Not suggesting you try it again
07-05-2012 10:08 AM
Although you can't see fine detail, it shows a general 24 hour pattern. I can of course replicate much finer detailed graphs if needed for the stored data within the RSL saving file.
Alex
07-05-2012 2:51 PM
07-05-2012 4:42 PM
SNRM seems a little more stable when it is hanging around the 9 level?
Not so much what I would call 'wild jumping'.
Or is it that my 'problems' have the day off on a Bank Holiday like everyone else?
Alex
07-05-2012 4:55 PM
07-05-2012 5:15 PM
07-05-2012 11:27 PM
09-05-2012 11:15 AM
See attached SNRM data for today........
09-05-2012 1:40 PM
