Intermittent Internet Service
- Intermittent Internet Service
Re: Intermittent Internet Service
02-05-2012 10:52 AM
I see Spencer has something in hand for tomorrow, so hopefully we'll know a bit more then.
Jojo
04-05-2012 9:16 PM
When is this ever going to end???
I was sat in my study when it started playing up....it had started to rain heavily 10 mins prior. Coincidence? Who knows?
I am totally and utterly fed up with all of this. It just is not funny anymore, I have totally lost my humour
Alex
05-05-2012 9:19 AM
05-05-2012 9:43 AM
05-05-2012 1:56 PM
As I said, it's probably a bad joint/crimp. With the length of your line it's going take a while to get them all looked at as well as getting Openreach to complete the rest of the network checks.
Has the new router I sent you arrived in the post yet?
05-05-2012 4:02 PM
Whatya think?
I got a bit sea-sick with all the ups and downs
Alex
05-05-2012 4:13 PM
Damn, forgot to say can you post the sync speed graph as well, looks like you had 2 re-syncs there.
05-05-2012 4:38 PM
only one resync I think at @ 10.36am (1472 to 1056Kbps)
will post more detaled graphs.....
05-05-2012 4:58 PM
05-05-2012 5:01 PM
Alex
05-05-2012 5:07 PM
Question......Do I have to do all the RSL settings each and every time I close and re-start the program (presume I do)....cause I had to do the settings all again.
Alex
05-05-2012 5:17 PM
I tell you what, have a look at the log, it will tell you the speed before and after anyway.
I'll also tell you a few short cuts -
Whilst you are on the Noise Margin graph, you can right click, you have some options - Capture now is a useful one, as is Open log , Open Capture folder. Copy to clipboard isn't as handy as you might think because you need to paste it elsewhere first, unless someone knows a clever trick, I'm no expert on image manipulation
05-05-2012 5:48 PM
Gonna try and get a whole day of stats again tom.
05-05-2012 6:07 PM
I notice that this Routerstats Lite v8.1 isn't displaying the current data at the bottom of the graph (unless you've cropped it). So if there are no sync changes for a particular graph, just say what the speed was. It there are sync speed changes, post the sync speed graphs as well.
I'm just going to send you a PM as well.
Edit: I'll engage brain - I've got v8.0 on one machine, v8.1 on another, and of course both automatically crop that data from the bottom when it saves. I'm so used to using the full version rather than the Lite.
06-05-2012 11:21 AM
As discussed
Alex
