Intermittent Disconnects
Fixes: 387
Re: Intermittent Disconnects
Can I suggest you post your Help Desk and error logs as I suggested please?
willcutforth
Fixes: 113
Hey there @jlog I'm back! Tested the line and everything looks swimming from our side. There was one drop today but prior to this there was on on the 16th. This will show you your visual connection.
 Will Cutforth
jlog
Thanks both.
Fingers crossed it’s a one off, I’ll keep an eye on it. If it does start happening frequently, I’ll pop the logs in here and raise another fault.
Cheers
Jamie
