Downstream sync speed
kidneybean1965
My downstream sync speed has dropped to 19.2mbps on fttc broadband. It has been at roughly this speed for about six days. My minimum guaranteed speed should be 29.2mbps. I had to unplug the router a couple of times last week, not sure if it’s a DLM issue. Any help would be appreciated.
21 REPLIES 21
adamwalker
Fixes: 223
Re: Downstream sync speed
Hi @kidneybean1965 I'm sorry that you're seeing some slow speeds at the moment, that must be really annoying!
It looks like DLM has dropped it down, however the connection seems to be stable again, I've popped a DLM reset through for you and it should improve things over the next 24 hours for you.
 Adam Walker
TeeGee
Seasoned Pro
I wonder how many people have a drop in sync speed and do not notice for a while?
My sync is 22Mbs and every now and again drops to 11.
A router rebbot usually fixes it but surely modern technology should be capable od correcting itself?
kidneybean1965
Okay, thanks for your help. I will keep an eye on the speed and let you know when it returns to normal.
adamwalker
Fixes: 223
No worries, do shout up if the issue continues past this time tomorrow!
 Adam Walker
Browni
Aspiring Hero
Fixes: 61
@TeeGee there is a technology known as SRA (seamless rate adaptation) although I've only seen it used on a G.fast connection.
kidneybean1965
I have waited a couple of days for the speed to improve, but unfortunately it has remained at 19.2mbps.
adamwalker
Fixes: 223
Sorry that's no better, would you be able to try a test whilst the router is connected to the test socket? https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
 Adam Walker
kidneybean1965
I am getting a download sync speed of 40mbps with the router connected to the test socket.
adamwalker
Fixes: 223
Thanks for letting us know, that could mean there's an issue with the socket, do you usually connect the router to it via a separate filter?
 Adam Walker
kidneybean1965
No the socket is an Openreach MK4. The engineer who fitted it said it does not require a separate filter. I have the router plugged into the test socket using a filter at the moment.
adamwalker
Fixes: 223
No worries and thanks for confirming, just to check do you have any other devices connected to other phone sockets if you have any?
 Adam Walker
kidneybean1965
I do not have any additional sockets.
adamwalker
Fixes: 223
Thanks, it would be best for us to book an engineer visit in that case. Can you let me know your availability in the following slots please?
Monday to Friday
AM = 08:00 to 13:00
PM = 13:00 to 18:00
 Adam Walker
RealAleMadrid
Fixes: 68
@kidneybean1965  It's possible that the modem resynced at the higher speed after moving the connection to the test socket. You will probably find that it will be the same if you put the faceplate back and connect using the built in filter. Give it a try.
If the speed drops there must be a problem with your master socket/faceplate.
