Intermittent Disconnects
jlog
Our connection has been stable for ages, but we’ve been encountering disconnects throughout the last couple of weeks. Is there anything that be can done to resolve this?
17 REPLIES 17
Fixes: 385
Re: Intermittent Disconnects
@jlog Try:
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
jlog
Cheers John, we don’t use a landline phone but think we might still have one in the garage. I’ll dig it out and give it a go.
willcutforth
Fixes: 113
@jlog let us know when you know Smiley
 Will Cutforth
jlog
Hi @willcutforth, no joy. If we have still got a phone I haven’t found it yet (turned the garage upside down looking for it 😄).
Still getting the disconnects (had one just now)
Fixes: 385
@jlog Which Hub have you got? the 'Help Desk' (Hub1) or 'Technical Data' (Hub2) would be an interesting bit of information - just remember to edit out any personal data before uploading.
jlog
Hi @jab1
It's the Hub 1 that I'm using. I've attached a screenshot of the Helpdesk.
I'm using Decos for my wi-fi hence it being disabled on the router.
Thanks.
Fixes: 385
'@jlog Looking at that screenshot, there are a couple of things that shout 'BT/OR network issue' to me. 1. You are getting xDSL drops on a regular basis 2. Your downstream SNR margin is much too low for your attenuation.
I would report a broadband fault via the second of the links I posted earlier, and hopefully @willcutforth or one of his colleagues will pick this topic back up.
If it is not too much trouble, could you also post the event log, please?
jlog
Thanks John @jab1
I will raise a fault.
Noddy Q, but can I export the Event Log or is it a screenshot jobby? If so, is there any particular filter you'd want applying?
Cheers.
Fixes: 385
On the Hub1, it is a screenshot (I think, never having had one). Don't bother about filters, and I only really need the current visible data. I'm just curious, that's all. 😀
@jlog
you need to filter on category WAN to see the connection details
HTH
jlog
Belated thanks John & Dan… I’ve not noticed disconnects for a while so fingers crossed it was a temporary issue.
jlog
Spoke too soon, just disconnected again Sad
Fixes: 385
@jlog Did you raise the fault, as you were going to do last month? Unless you do, the underlying issue will not go away.
jlog
Hi @jab1
I did send a text to raise a fault, subsequently missed a call from Plusnet but the voicemail said they’d get back in touch… they never did though. I didn’t follow up as we were away from home for a bit and upon return hadn’t noticed any disconnects until now.
I’ll raise a new one if this morning’s isn’t a one-off.
cheers,
Jamie
