Installing new BT Master socket and rewiring
- Re: Installing new BT Master socket and rewiring
- « Previous
- 1
- 2
- Next »
21-02-2009 10:04 PM
Quote from: mal0z
Looks like we will see if there is a telephone line "fault"
Maybe a loose screw is causing a noisy line or intermittent fault?
Message 16 of 21
(614 Views)
21-02-2009 10:24 PM
Now would I do a thing like that......................
Message 17 of 21
(614 Views)
22-02-2009 2:49 AM
The solid conductor cabling that BT use to enter the house is a swine too, easily breaks due to fatigue with too much flexing especially with older wire like your friends sounds to be.
Message 18 of 21
(614 Views)
22-02-2009 2:59 AM
Quote from: pierre_pierre nearly as bad with electrics, you can do some work but not much
To read the info leaflets that many of the council planning departments are putting out you would think that that was the case. But a few months ago I was talking to a couple of electricians refurbishing my mums council bungalow, who said that it is possible to do most electrical work yourself, its just that it has to be signed off by a qualified (certifying) electrician before the house is sold etc.
Message 19 of 21
(614 Views)
22-02-2009 1:24 PM
Your right Glyn
My pals phone wiring is about 50 years old - so rather than do half the job and get stuck - I'm inclined to let the BT technician do it. he can afford it :), he's just spent £900 on a new laptop.
Message 20 of 21
(614 Views)
22-02-2009 3:38 PM
Quote from: mal0z It is an older property with no BT Master socket - just sockets wired on the very old style junction boxes, and the wiring is very untidy.
It would be a good thing if that ring wire was loosened and fell out from the 1st box where the wires enter the house
3Mb FTTC
3Mb FTTC
Message 21 of 21
(614 Views)
- « Previous
- 1
- 2
- Next »
