Another login problem
- Another login problem
19-02-2009 9:18 PM
I've logged in to check my broadband usage this month.
I click Webmail and I now want to Log In to check something in the Webmail area but I can't.
The Webmail Login Box tells me I must be logged in to do this login.
I dont often do this. Have I done something wrong once again?
Message 1 of 4
(1,097 Views)
3 REPLIES 3
Re: Another login problem
19-02-2009 9:27 PM
You need to login with the mailbox name in the format username+mailbox name and the password for that mailbox
Message 2 of 4
(389 Views)
22-02-2009 5:39 PM
Can't find where it tells me to login like that.
Message 3 of 4
(389 Views)
22-02-2009 6:38 PM
Go to here https://webmail.plus.net/src/login.php and you will see
Other way to get there is to click on Member Centre and click on webmail in the left hand column
Message 4 of 4
(389 Views)
