IP Profile speed drop
caldwellmark83
Hi, my speeds have dropped quite considerably over the last few days and restarting my router hasn't done anything.
Referencing this thread : https://community.plus.net/t5/Broadband/IP-Profile-speed-drop/td-p/1833996
Seems my line is restricted to only 16Mb download speeds and 20mb upload but as you can see I'm not even getting that (see attached screenshot)
Any idea if there is some restriction on my line that has happened as I need to get this resolved asap as my partner and I both work from home.
I'm on Fibre so should be and I was getting far higher speeds, can anyone help?
17 REPLIES 17
caldwellmark83
Re: IP Profile speed drop
Fixes: 387
@caldwellmark83 Looking at that you have a problem, definitely. Which router are you using?
caldwellmark83
Hi John, thanks for your reply.
I am using Plusnet Hub One.
Fixes: 387
In that case, can you follow the below, please, although I suspect the result to be 'report a fault'.
BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS'- if it will run. This test is recommended to be performed with only one device connected.
For the Hub One -
For the Hub Two -
caldwellmark83
Weirdly nothing comes up when I try to search on https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome even just by postcode
And unfortunately, I don't have an ethernet cable so I just ran the test wirelessly again...
and for
For the Hub One -
Navigate from the Home Screen to Troubleshooting > Helpdesk...
and unfortunately, I've no phone to test the line
Fixes: 387
Pity you don't have a phone, but what you have posted is enough - report a broadband fault via: https://www.plus.net/help/report-a-problem/  and please let us know the response.
caldwellmark83
Using the word unfortunately too many times here! but I did try that and I got a message to say I needed to respond with the word FAULT and my landline number but I don't know it and can't find it under my account, I checked under Manage Account and the telephone number listed there is my mobile number
Fixes: 387
Your phone number is shown on the page that opens when you click 'Manage account details'.
caldwellmark83
Yeah that's what's a bit confusing as the Telephone number just has my mobile number in it, when I signed up I got email...
Remember, your new service does not include a home phone
• If you have a home phone number, you'll lose it as part of this order.
• There will be no dial tone and you won't be able to make or receive calls, including emergency calls, on your home phone. To dial the emergency services you'll need to use a mobile phone.
• Any services and personal alarms which are connected to your home phone service will stop working and you'll lose your existing home phone number.
• If you later decide to switch back to a broadband and landline service, you won't be able to use your previous home phone number and will receive a new phone number.
Your broadband speed
Here's all the speed details you need to know.
Fibre has an average speed of 50Mb download and 9Mb upload.
At peak times, we estimate that you'll get the following speeds on your line:
Download: 64 - 72Mb
Upload: 0.5Mb
Minimum Guaranteed Speed: 58.3Mb.
I think I'm just on the Fibre product, although I thought you still had a phone number with this but in the case of my contract I just can't attach a phone for calls.
Sorry, I find this all a bit confusing so thanks for the help
Fixes: 387
Ah, so you are on a SOGEA  connection, which as you were told does not have a phone element. Your only option in that case is to call in and report the fault - 0330 123 9123.
caldwellmark83
Thanks John, I've been googling how to find it out so been going round in circles, I'll give them a call
Fixes: 251
Redacted - someone transposed two digits ... Embarrassed
Thank you @MisterW ... though the speeds being seen match the profile of the transposed digits modulation speed!
Fixes: 585
I think you've got some 2s and 3s missplaced there @Townman , its reporting 993.2 (VDSL) but to be fair, the upstream does look mighty wrong!
caldwellmark83
Getting worse, just carried out another test. Is there any way to escalate on here as seems easier to diagnose and solve with screenshots etc than over the phone?
