Disconnects - Line Check Please
superuser
I'm recently started getting unstable notifications on Zoom meetings
When I examined the router log I could see the line has been dropping
Had this before a year or so ago
Could a line check be done?
Everything in the house is unchanged
6 REPLIES 6
Fixes: 391
Re: Disconnects - Line Check Please
which router are you using? If you have a landline phone, is it clear - dial 17070, select option 2 - there should be silence after confirmation of your number, apart from the regular 'Quiet Line Test' message.
superuser
No landline
Not part of my package
Asus DSL-AC68U
Line Attenuation (dB)
2.8
10.5
19.8
25.8
30.1
41.2
Signal Attenuation (dB)
2.8
10.8
19.7
26.1
29.6
41.5
SNR Margin (dB)
9.4
6.2
9.5
6.4
9.4
6.7
9.4
5.6
superuser
Speeds are OK
SNR Margin
7.1 dB
9.4 dB
Line Attenuation
10.5 dB
19.8 dB
Path Mode
Interleaved
FastPath
Interleave Depth
8
1
Data Rate
79342 kbps
14999 kbps
Max Rate
100936 kbps
20069 kbps
Fixes: 391
The stats above look fairly reasonable, except possibly the D/S SNR.
Is it possible on that kit to export the logs in .csv format?
superuser
Sadly No
But since my post, now it's been up without dropping. 4 days now
Fixes: 391
OK.
