IP Profile change please
- IP Profile change please
Re: IP Profile change please
22-11-2010 10:35 AM
I'm sure the faults guys will get to the bottom of it once they get their teeth into it.
Jojo
22-11-2010 10:42 AM
As I pointed out here in a previous topic (topic,89000.msg746087.html) a couple of months ago, BT lower the rating for your acceptable speeds when they lower actual speeds. Then if/when your speed goes back up, ... up goes the "acceptable range".
Also, I think the chart that you were given was showing breaks of PPP link to Plusnet. That can break without losing sync with the exchange, despite what some people will have you believe, as I have also pointed out on posts to this forum.
22-11-2010 8:42 PM
I do not expect, 4 days after making a complaint, for the situation to deteriorate further, but yet it has.
23-11-2010 10:15 AM
I'm sorry to hear there's been no improvement. I've been looking for your complaint from 4 days ago but can't see it. The only one I can see was raised at 16:00 on 20/11/2010. Is this the one you mean?
Jojo
23-11-2010 7:40 PM
24-11-2010 11:31 AM
excellent, 4 days of inactivity on a live call and you've done nothing, infact its daily getting worse.
What exactly was your award winning for, hacking off custoimers.
I now regret ever moving over to plusnet.
24-11-2010 11:47 AM
Last time you posted them you were getting:
Quote from: DBB Link Information
Uptime: 0 days, 8:28:25
Modulation: G.992.1 Annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 2.336
Data Transferred (Sent/Received) [MB/GB]: 117,92 / 2,73
Output Power (Up/Down) [dBm]: 11,5 / 17,5
Line Attenuation (Up/Down) [dB]: 31,5 / 61,0
SN Margin (Up/Down) [dB]: 19,0 / 6,5
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Signal (Local/Remote): 10 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 845 / 0
FEC Errors (Up/Down): 98 / 9.621
CRC Errors (Up/Down): 0 / 327
HEC Errors (Up/Down): 0 / 285
I'd like to see how they have changed.
24-11-2010 3:15 PM
I notice you have been contacted by one of our faults team today.
Just for clarification...
[quote=DBB]Reply #16 on 18/11/2010, 15:30 was the initial compliant.
Reply#17 was by me 17 minutes later.
Jojo
24-11-2010 5:22 PM
ATM Status
Status Uptime (hh:mm:ss) Max. Theoretical Speed (bits/sec)
UP 04:07:20 2592000
ATM Statistics
Octets Cells Unicast Non-Unicast Total Dropped Errors Invalid Queued
Tx 31284855 651767 487266 0 487266 0 0 N/A 0
Rx 1272249660 26505201 868292 0 868292 0 7010 0 N/A
ATM/AAL Status/Statistics
VPI/VCI Protocol Admin Status Oper Status Tx-Rate (kbps) Rx-Rate (kbps) Tx-PDUs Rx-PDUs Tx-Errs Rx-Errs
0/38 PPPoA UP UP 448 2592 487266 868292 0 7010
Lines continually dropping, why its started to do this I don't know, ex. dropped at 6.30am with pc off overnight.
27-11-2010 1:02 PM
you are having a joke, aren't you.
I WAS on a stable 2.75mbps with tiscali, and now this (and I was told I would not have a drop in speed by going to plusnet).
Every time you ask me to retest my equipment I DROP speed. This is now unusable.
What is the route for compensation regarding this as I am now totally [Censored] off.
When is the BT engineer coming, I was told it was monday, or do you now want to to wait in all day monday on the off chance as you can't be bothered to inform me whats happening.
28-11-2010 2:05 PM
29-11-2010 11:24 AM
I can assure you we're doing everything we can for you. Hopefully the engineer visit today can resolve it.
Jojo
29-11-2010 12:07 PM
I'm sure he'll let you know the rest, although my understanding is he found nothing.
I'll now have to leave it 10 days so the line can retrain as profile now at 750..
29-11-2010 2:20 PM
Your sync rate is now 2432 so this will give you a profile of 2000 if the line doesn't have any disconnects.
Jojo
29-11-2010 7:13 PM
however, since my synch speed is dropping, and I have numerous errors occuring I think it may be a good time for you to recall BT and get them to actually sort this as its been 12 days now without having the broadband speeds I was promised before switching, or even a broadband speed that is fit for purpose.
