I can't access Npower website.
- Re: I can't access Npower website.
- « Previous
- Next »
06-05-2015 2:10 AM
I got some weird results
So an MSS of 1465 from here, but I did a trace re incomplete path message
This was rather strange, look how its looping on itself.
Quote C:\Users\kitz>mtupath www.npower.com
MTU path scan to www.npower.com (46.18.118.60), ttl=64, limit=48
# 16 processing - best MSS 1465 (estimated MTU 1493) [uUUUUuUuuUuuuUUU]
# 08 nearest minimum MTU on 195.166.130.204 (2 hops away)
#1 MSS IN RANGE 1 <== 1464 ==> 1465
#2 MSS EXCEEDED 1466 <== 14918 ==> 16384
[WARNING] Could not confirm contact with peer; path may be incomplete
C:\Users\kitz>tracert www.npower.com
Tracing route to www.npower.com [46.18.118.60] over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 11 ms 11 ms 11 ms lo0.11.Central11.ptw-bng02.plus.net [195.166.130.204]
3 11 ms 11 ms 11 ms irb.11.PTW-CR02.plus.net [84.93.249.18]
4 12 ms 12 ms 12 ms 195.99.126.182
5 20 ms 15 ms 15 ms 109.159.254.149
6 12 ms 12 ms 12 ms transit2-xe-0-0-0.ilford.ukcore.bt.net [194.74.77.174]
7 12 ms 12 ms 38 ms t2c4-xe-9-3-0-0.uk-ilf.eu.bt.net [166.49.168.125]
8 12 ms 12 ms 12 ms xe-9-0-1.edge3.London1.Level3.net [195.50.124.69]
9 12 ms 13 ms 12 ms ADVERSOR-LI.edge3.London1.Level3.net [195.50.124.66]
10 * * * Request timed out.
11 13 ms 12 ms 12 ms 46.18.118.60
12 12 ms 12 ms 12 ms 46.18.118.60
13 13 ms 13 ms 12 ms 46.18.118.60
14 13 ms 14 ms 12 ms 46.18.118.60
15 12 ms 12 ms 12 ms 46.18.118.60
16 13 ms 12 ms 13 ms 46.18.118.60
17 13 ms 12 ms 13 ms 46.18.118.60
18 20 ms 20 ms 20 ms 46.18.118.60
19 22 ms 22 ms 22 ms 46.18.118.60
20 20 ms 22 ms 22 ms 46.18.118.60
21 21 ms 22 ms 22 ms 46.18.118.60
Message 31 of 36
(727 Views)
06-05-2015 6:43 AM
As you are using Chrome - do you have the Adblocker plug in installed?
That's a known culprit for this sort of behaviour even on sites without ads to block.
If you have it installed, switch it off, restart browser and try again.
Message 32 of 36
(727 Views)
07-05-2015 11:42 AM
Solution at last thanks to Adrian, my PC provider/ super tech wizard.
He found that the PC WiFi software had been corrupted and that was the cause of the problem. He uninstalled it and hey presto. I am back on Npower's site.
The PC is actually working by cable to the router so it was not obvious the the WiFi connection could be the cause of the problem.
Thanks Adrian.
Thanks Adrian.
Message 33 of 36
(727 Views)
07-05-2015 12:36 PM
Interesting - glad it's resolved for you.
It does make you wonder about this though...
Quote from: deathtrap I too can't access this site using it's dns hostname,
Message 34 of 36
(727 Views)
07-05-2015 7:37 PM
Message 35 of 36
(727 Views)
08-05-2015 9:38 AM
Thanks for letting us know the cause of the problem.
No one would have guessed that
Message 36 of 36
(727 Views)
- « Previous
- Next »
