Hub reboots
Fixes: 383
Re: Hub reboots
I'll leave the log to Dan, and hold off on reporting anything until he's had a chance to peruse the log.
grizedale
Re: Hub reboots
Going to be 2 or 3 hours till i can respond.
Re: Hub reboots
@grizedale
without the need of a coffee I have viewed the log file and found many  (57 in total)
07:45:36, 09 Dec. System start Button press (PowerButton)
07:45:36, 09 Dec. System up
07:22:59, 09 Dec. System start Button press (PowerButton)
07:22:58, 09 Dec. System up
I have to ask but is anyone turning the Hub off using the power button and if so why? If is not deliberate it could be a dodgy power switch causing the Hub restarts. It's not unknown for these small power switches to go intermittent. A replacement Hub would be needed.
However you are getting DSL Link Down as well, which would be a broadband connection disconnect, this needs investigating, could be caused by noise on the landline.
If you have a NTE5c MK4 master socket with a filtered faceplate, it might worth using a inline filter connected to the test socket found behind the faceplate, it is not unknow for the seating of the faceplate and test socket to become flaky causing line noise.
Report a phone fault:- https://www.plus.net/help/report-a-problem/phone/#phone
Report a broadband fault:- https://www.plus.net/help/report-a-problem/broadband/
HTH
grizedale
Re: Hub reboots
Re turning off, Yes I am, the hub will suddenly go to solid orange and remain there till its rebooted..
grizedale
Re: Hub reboots
We have a 5C master socket with seperate wifi and phone sockets.
I have attached a copy of the latest log, I have been out for 5 hours so its been untouched for that long.
Re: Hub reboots
Solid Orange means the Hub is working but not connected to the internet, you are getting ERROR_NO_CARRIER messages which the Hub appears to be slow to recover from, I would expect this is the cause the solid orange light. There have been 8 ERROR_NO_CARRIER messages for today alone.
You landline might have periods of noise on it which could prevent the broadband connection from reconnecting, a wired phone would be handy to check for this
I would raise a broadband fault using the link I supplied previously, hopefully it will detect an error.
HTH
grizedale
Re: Hub reboots
Thanks Dan
Is there nothing more can be done from your end then?  Since logging on this morn it's gone off approx every 5 minutes 5 times .  As you can imagine it's very frustrating.
Should I report a phone fault or a broadband fault do you think?
Any possibility I could be sent a new hub?  I've been with you many years and don't intend to leave anytime soon.
grizedale
Re: Hub reboots
Fixes: 383
Re: Hub reboots
@grizedale wrote:
Thanks Dan
@grizedale Neither I or @Dan_the_Van are Plusnet staff - merely Community members who try to help others, and without trawling back, I seem to remember you were advised to report a broadband fault, which will now not have any action by Openreach until, possibly, Wednesday.
Re: Hub reboots
@grizedale
As I mentioned before the Master Socket 5c faceplate can cause issue if not fully seated. If you have a in-line ADSL dongle filter try using that connected directly to the test socket behind the faceplate to see if that improves the situation.
Other than that I raise a fault.
HTH
Fixes: 246
Re: Hub reboots
Getting a handset is probably going to be the quickest way of nailing this issue.  Without one, YOU cannot determine if you have a dial tone or the line is noisy.  Until such is eliminated, you are likely to go around in circles and not reach a quick resolution.
No dial tone or noise points to a copper circuit fault.
Good dial tone and a silent line points to a broadband fault.
Each has a different repair process and engineers.
grizedale
Re: Hub reboots
Thanks for all your help.
I reported the issue via text (what an efficient process), and there is a fault at the exchange which will be looked at Mon/Tues.
Fixes: 383
Re: Hub reboots
Cheers @grizedale - let us know the outcome, please.
grizedale
Re: Hub reboots
Text message @ 15:10 today to say that they have fixed the issue. Thanks to all.
Fixes: 383
Re: Hub reboots
Does it appear fixed to you?
