Constant green light before broadband activation
cdavies94
Hello all,
I've just moved to a new flat and have taken Plusnet with me; it's due to be activated tomorrow.
I just tried to turn on my router and noticed there's a constant green light instead of orange. I was hoping to use it for LAN purposes (to connect speakers which need a local network) but it didn't work. I did a quick Google search and found old posts suggesting that a green light implied a faulty router.
My question: is this normal behaviour before activation, or do I need to order a new router?
24 REPLIES 24
Fixes: 334
Re: Constant green light before broadband activation
Which Hub are you using?
cdavies94
It's a Hub 2.
Fixes: 334
Try rebooting the Hub - Press a paper clip or similar into the reset hole, hold for 25-30 seconds, or until the light turns green again, and then wait for five minutes or so.
Report back with the result.
Edit: If you are due to connect tomorrow, it won't be active anyway, so maybe hold off until then.
cdavies94
Already tried this - no change!
Fixes: 334
See my EDIT - you have no connection to the internet, so it won't work, anyway.
Fixes: 531
You would normally expect it to show flashing orange i.e seraching for a dsl signal.
@cdavies94 do you have anything connected to the hub ? if so try disconnecting everything , then resetting the hub without anything connected
Fixes: 334
@MisterW Never thought of that - oops - but is it worth trying anything until the OP has an internet connection?
Fixes: 531
Yes, if it has just a green light with nothing connected, then it looks like its not starting up properly i.e faulty
Fixes: 334
OK , got you. The cold must be freezing my brain - I'm not usually that dim 😁
cdavies94
Yes, this was my fear..
What's the best way for me to replace it? Ask Plusnet for a new Hub or pick up a generic (TP-Link?) router from Curry's? I guess the former might take some time, and I need to be online ASAP
Fixes: 124
@cdavies94 was this the working Hub from your previous property?
Are you using the correct power adapter for it?
Dan.
cdavies94
Yep, everything is the same as my previous property.
Fixes: 124
Pity, with two more postal strikes this week buying a 3rd party device might be quickest. Just make sure its a combined modem/router supporting ADSL/VDSL connections
Dan.
Fixes: 459
@cdavies94
The green light is part of the standard start up sequence, it's a case of how long it stays green. Have you tried the factory reset as suggested by @jab1 earlier? Try holding the switch closed for about 30 seconds.
