How to get stats from a router?
- Re: How to get stats from a router?
30-01-2013 8:59 PM
When I login to admin on Technicolor TG582n router, I can't find any link to show me what the upload and download are currently connected.
I like to see stats from a router.
Message 1 of 9
(1,520 Views)
8 REPLIES 8
30-01-2013 9:05 PM
You can't as you are on fibre
Other than hacking the modem the only way to get an indication of download speed is the BT IP profile and multiply it by 1.033
Message 2 of 9
(719 Views)
30-01-2013 9:05 PM
Try http://192.168.1.254/cgi/b/dsl/dt/?be=0&l0=2&l1=0
Message 3 of 9
(719 Views)
30-01-2013 9:10 PM
Above only works on DSL not FTTC! It actually shows on my 582n on fibre as DSL Disconnected!
dick:quote
dick:quote
Message 4 of 9
(719 Views)
30-01-2013 9:27 PM
That's to be expected as the router is not connected to any DSL - it's the modem that does that.
PS I suggest you change your signature before you get in to trouble with the moderators! See http://community.plus.net/forum/index.php/topic,218.0.html#post_avatar
Message 5 of 9
(719 Views)
30-01-2013 9:44 PM
Okay, sorry did not realise, hope this is better?
jim:quote
jim:quote
Message 6 of 9
(719 Views)
30-01-2013 9:50 PM
Pah! "The use of advertising links which confer a benefit to the poster
Quote from: jelv See http://community.plus.net/forum/index.php/topic,218.0.html#post_avatar
Message 7 of 9
(719 Views)
30-01-2013 10:04 PM
So it is not possible to find what the max speed currently connected from a modem or router? Thats Odd.
Basically I have to use speedtest.net or BT speedtest to check..
Message 8 of 9
(719 Views)
31-01-2013 12:48 AM
You need your BT IP Profile, not a speedtest result. To get your BT IP Profile you need to do a BT speedtest, than ask for Further Diagnostics and enter your phone number. Then as Oldjim said multiply that value by 1.033.
David
Message 9 of 9
(719 Views)
