How to find log in details for own modem/router
Unclfesta
I’ve got an issue with my hub 2 and I have a TP Link Router/Modem that is compatible with Fibre from cabinet. In order to log in I need the user name and password that Plusnet have allocated ( not my username and password used to log into app).
I can’t find it anywhere and have sent support a message through X (old twitter)
Can anyone help or advise?
TIA 👍😊
3 REPLIES 3
Fixes: 528
Re: How to find log in details for own modem/router
https://www.plus.net/help/broadband/broadband-connection-settings/
jwsg
To log into the Hub ? - details on the hub label
To connect a router ? - https://www.plus.net/help/broadband/broadband-connection-settings/ the username and password would be same as logging into your broadband account in a web browser - there is no app for this - in the Hub the username is found in home ->  advanced settings -> broadband
Unclfesta
Thanks so much for your reply. Very clear and was simple to sort.
Thanks again 👍😊
