Connection dropping out
mike40
Has there been some issues on Plusnets end with vdsl connections, it's been unstable since Friday maybe Saturday not too sure as I wasn't at home Friday. It went down on Sunday morning for about ten minutes, it went down just five minutes ago. A reset of the router does nothing.
3 REPLIES 3
Fixes: 387
Re: Connection dropping out
@mike40 I doubt it is a problem 'at Plusnets end' - more likely an issue on the OpenReach network.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
mike40
Ok thanks. Openreach have been doing a lot of work lately probably laying out FTTP, but until the last few days it's been fine. We don't have a phone line so I'll keep an eye on it and use option 2 if it continues, the problem is that because it does keep dropping we've lost about 10Mbps of speed from where it was.
Mike.
Fixes: 387
I would suggest using option 2 immediately - chances are you have an OR network issue, not necessarily caused by the work being carried out.
