How to confirm what lin speed you should be getting
- Re: How to confirm what lin speed you should be ge...
- « Previous
- 1
- 2
- Next »
Re: How to confirm what lin speed you should be getting
27-03-2014 3:05 PM
hi please see image attached, rebooted last night hence the 15hrs uptime.
Cheers
Cheers
Message 16 of 23
(481 Views)
27-03-2014 3:07 PM
Quote from: Chris Has anything been moved or been changed in your internal setup? The increase in SNR will be the reason for the drop in sync rate.
Message 17 of 23
(481 Views)
27-03-2014 3:20 PM
Quote from: Chris Your SNR has crept up to just over 10db (6db Target).
Hi
No nothing has changed, i noticed the speed drop to 2.5MB last night and rebooted the router, around 10pm the speed is no up to 3147, but not as high as it was earlier one yesterday at 4.5mbs
Message 18 of 23
(481 Views)
27-03-2014 3:28 PM
I'm not sure what's happened to drop your speeds other than your SNR increasing.
I would leave your connection for a few days and allow the line to settle and see if things improve.
Message 19 of 23
(481 Views)
27-03-2014 3:37 PM
Wouldn't it be worth temporarily connecting the modem/router to the TEST socket (behind the master socket faceplate) to see what the line is actually capable of ?, and then proceed from there, knowing how much of a speed drop is due to the extension wiring.
Message 20 of 23
(481 Views)
27-03-2014 3:52 PM
that was gonna be the next thing.
Message 21 of 23
(481 Views)
27-03-2014 9:52 PM
Hi noticed the snr has increased from 7.5 till 10.1 is that right in space of 6hrs?
Message 22 of 23
(481 Views)
28-03-2014 9:27 AM
The SNR is supposed to be adaptive. It will adapt it's value depending on line conditions.
Did you manage to connect into your Test Socket?
Message 23 of 23
(481 Views)
- « Previous
- 1
- 2
- Next »
