How to confirm what lin speed you should be getting
duffy
I am meant to be on ADSL2+ but I am only getting 1.4 MB! which really sucks to say the least, (and i though 2.5MB sucked when i had that)
how can i confirm if i am indeed on adsl2+
Link Rate is D/S 1411 U/S 728
Line Att is D/S 52.0db U/S 26.4db
Noise Margin is 9.6db u/s 7.3db
Cheers in advance
Re: How to confirm what lin speed you should be getting
Can you post the speed estimates from here http://www.dslchecker.bt.com/ ?
duffy
Thanks for the speedy reply (unlike bB lol)
duffy
Also can someone confirm when they are going to upgrade the CAB129 i am off in Erdington, please? or point me in the right direction of a roll out plan
I have a shiny new Fibre one on the other side of the road which i am NOT connected to Sad , just taunting me and has been doing so for the past 18mths or so.
Based on your line attenuation figures, you should be getting closer to 4Mbps.
Are you connected to the master socket? Have you had any problems with disconnections?
duffy
No not connect to master socket, thats in the assuming that is in the lounge connected in the bedroom upstairs.
silly question for you how do i tell which is the master sock?
Yes I have had problems with disconnections
duffy
duffy
Bedroom 1 phone socket with 5M extension lead, then in to attenuator, then router and fax connected
downstair 1 Phone socket and attenuator  with phone attached
Will look something like this (look at the bottom of the page) - http://www.plus.net/support/broadband/speed_guide/speed_tips.shtml
It has a removable front plate.
I did try to see if I could find anything about your fibre rollout, but there was nothing Sad
duffy
Ooh think i done a whopping 4MB!  plugged the router in to the phone socket directly (with attenuator) , now just have move everything around, so i dont trip over the phone cable lol
Cheers Smiley
(bedroom socket not the master one btw)
Whell thank for trying to find out about the fibre roll out for me 4 times as quick is better then nothing Smiley
You might not get the full speed quite yet, because your IP Profile might need to update. What is your Current Line Speed here https://portal.plus.net/my.html?action=data_transfer_speed ?
duffy
Cheers will keep an eye on it over the next 5 - 10 days
duffy
dropped to 2375kbs  Sad  any advice andyh please?
Is that the sync rate that dropped? Did you lose connectivity?
Can you post your router stats again?
Plusnet Staff
Plusnet Staff
Fixes: 5
Your SNR has crept up to just over 10db (6db Target).
Has anything been moved or been changed in your internal setup? The increase in SNR will be the reason for the drop in sync rate.
Chris Pettitt
Cloud Environments Engineer
