Has the BT speedtester changed
- Has the BT speedtester changed
08-09-2009 12:02 PM
Re: Has the BT speedtester changed
08-09-2009 12:17 PM
08-09-2009 12:22 PM
Am now trying to find out why as the router is still synched at 4000kbps although with a reboot early this morning showing up in the log but nothing else
08-09-2009 12:24 PM
08-09-2009 12:24 PM
Looks like another cunning BT plan - won't accept fault reports without speed tests and won't let you run speed tests!
08-09-2009 12:47 PM
08-09-2009 12:52 PM
Download speedachieved during the test was - 887 Kbps
For your connection, the acceptable range of speeds is 200-1000 Kbps.
Additional Information:
Your DSL Connection Rate :1184 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 1000 Kbps
08-09-2009 1:03 PM
08-09-2009 1:04 PM
Apparently 600kbps - 7150kbps is "acceptable"
08-09-2009 1:08 PM
Quote from: Oldjim you missed the little tick box - took me a while to spot it as well
08-09-2009 1:14 PM
Quote from: Crucibleofevil Apparently 600kbps - 7150kbps is "acceptable"
400Kbps was "acceptable" on IPStream and IPStream Max.
08-09-2009 2:21 PM
As if there isn't already enough confusion with terms, during the 'testing' phase, it states that my 'configured download throughput speed' is 3000. Er, no, that's the IP Profile. On the 'results' page, it correctly calls it the IP Profile, and 2670, correctly, as the 'download speed'.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
08-09-2009 2:24 PM
08-09-2009 3:37 PM
Quote from: Jameseh Yep - The service ID is your CBUK number, which you shouldn't need to enter, because I doubt you'll know what it is!
Not all of them are CBUK some are BBEU and can be found from the tickets.
08-09-2009 3:46 PM
Quote from: Jameseh
If your profile is below 2000 than the acceptable range change to 400kpbs-2000kbps. I know this as my profile until today was 1750 and I was seeing this yesterday when I was checking to see how quickly BT DLM system increased my profile. It took between 22 to 26 hours and then another 12 to 16 hours for PN to follow. So it took 38 hours from a higher resync, system generated, to go from a profile of 1750 to 2500.
