Has the BT speedtester changed
- Has the BT speedtester changed
- « Previous
- 1
- 2
- Next »
Re: Has the BT speedtester changed
10-09-2009 2:09 PM
Well it eventually worked, on a second attempt - no change there then
I can see the boards and the CSC getting more queries from those that miss the tick box and also want their Service ID
As for the acceptable range, well looks like its just another excuse for dodging any speed faults
Message 16 of 23
(353 Views)
10-09-2009 3:59 PM
Still hangs under Firefox on Linux, to the point of me having to terminate FF and restart it.
Message 17 of 23
(353 Views)
11-09-2009 3:43 PM
With this new tester does the speed test go anywhere near the Plusnet speed restriction.
I ask because my profile has just recovered from 3000 to 3500 (Plusnet haven't caught up yet) but the BT speedtest result is what I would expect from a 3000 profile.
Message 18 of 23
(353 Views)
11-09-2009 3:47 PM
Does anyone fancy generating a library article on "How to do a BT Speedtest" on various Operating Systems (if applicable? :))
B.
B.
Message 19 of 23
(353 Views)
11-09-2009 3:55 PM
I could only do it for Windows systems - and it is self explanatory for them once you spot the little tick box - and a sticky would probably cover that..
Actually on second thoughts should it be part of the Plusnet Help System given that they (well BT) insist on 3 tests before a fault will be accepted.
Either way I can do one for windows XP, Vista and Windows 7 and then someone else could add the Mac and *nix bits as that is where the problems are more likely to appear since the BT programmers probably didn't check on the various options.
Note to self - check if it needs Java still
Message 20 of 23
(353 Views)
11-09-2009 3:55 PM
Well volunteered Jim
Message 21 of 23
(353 Views)
11-09-2009 4:04 PM
Can't start yet as I need to wait 3 hours before I can do another test and take the screenshots.
Also I want to check what needs to be put on the second screen as the only bit which is mandatory is the usename and not the plusdsl.net
I want to try it with java and javascript disabled first.
At least it doesn't use flash
Message 22 of 23
(353 Views)
11-09-2009 7:38 PM
some of the optional questions could do with explanations, but it did run OK
Quote Download Speed
5768 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 5768 Kbps
Additional Information:
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
Message 23 of 23
(353 Views)
- « Previous
- 1
- 2
- Next »
