Has my Technicolor TG582n router been hacked?
- Re: Has my Technicolor TG582n router been hacked?
18-03-2015 8:37 PM
I'm the only one with the password to this router, and I know I didn't change it. I can't see any other way it could have changed unless someone else has got access to it now.
The router says it has version 8.4.4.J of the firmware. doesn't seem to be a way to check for updates on the web config page.
Has it been hacked? is the firmware vulnerable? And now what do I do with it?
18-03-2015 9:06 PM
you should just be able to change it back to your account details.
18-03-2015 9:50 PM
18-03-2015 9:52 PM
18-03-2015 10:09 PM
"Auto Setup" can be disabled in the plusnet members centre.
https://portal.plus.net/automatic_hardware_setup/index.php
The following link explains how TR69 works.
http://www.plus.net/support/broadband/hardware/tr69faq.shtml
Also this feature can be disabled in the Technicolor routers, it called CWMP in the routes configuration.
http://npr.me.uk/telnet.html#cwmp
18-03-2015 10:11 PM
18-03-2015 10:30 PM
Quote from: mwarby is tr-69 line or MAC based, if latter and modem was obtained say by ebay(had to get one this way for my mum, plusnet wanted silly money for a replacement) that could explain it
That's not the case for me, I'm still using the original router I received from plusnet when I joined a few years back. I've not seen anything like this until today.
Quote from: npr I agree this sounds like TR69 auto setup working , ie Plusnet pushing a username and password to the router.
Thanks for the links, it does suggest that my router serial number is now associated with the wrong account. Possibly just an error, maybe their staff mistyped the serial number while setting up a new account for someone else. I'll trying calling the Plusnet support if I get a minute tomorrow, since I suspect the owner of ala****1988@plusdsl.net is probably sat with a useless modem at present...
Thanks for the help
18-03-2015 10:41 PM
I assumed that setting was allocated to the line not the router but I could me wrong.
Quote from: asjnsaofnsado I suspect the owner of ala****1988@plusdsl.net is probably sat with a useless modem at present...
The username and password can always be manually entered in the router, allway the best option IMO
18-03-2015 11:05 PM
The problem is that if ala****1988@plusdsl.net opted for fixed IP, both your connections would stop working correctly.
I just hope that ala****1988@plusdsl.net is on unlimited because your usage will be being recorded against his account (I think you'll find VMBU is not showing any usage for you).
[me=jelv]wonders if there's been more screw ups like this and it accounts for some of the users reporting no usage showing in VMBU[/me]
19-03-2015 2:20 AM
Quote from: jelv [me=jelv]wonders if there's been more screw ups like this and it accounts for some of the users reporting no usage showing in VMBU[/me]
That's an interesting thought. As the owner in this case has had the 582n for some time, I'm wondering if whoever entered the details in the TR-069 database needed their reading glasses on!
@asjnsaofnsado
Did you by any chance join in 2012?
19-03-2015 7:46 AM
Welcome to the forums.
1. The auto configuration is associated with the router's serial number, which is associated with an account, not the line it is connected to
2. Switching auto configuration off is not going to help if the serial number of your router is miss associated with another account
3. There was another recent incident of someone seeing constant drop outs caused by another user using their login credentials - I suspect arising out of a similar failure - see http://community.plus.net/forum/index.php/topic,137563.msg1210818.html#msg1210818
This problem needs urgent CRT attention.
