Flashing orange router
FIXED- Subscribe to RSS Feed
- Re: Flashing orange router
Thursday
Thursday
You need to change the browser you are using to use 'desktop site'
For google chrome, with the reply window open, top right three dots, select Desktop site.
This should expose the paper clip icon below the reply box.
Thursday
Thursday
thanks this may have doneit
Thursday
Thursday - last edited Thursday
Post deleted
Thursday
@tearlec Anything on the log?
Thursday
12 hours ago
12 hours ago - last edited 12 hours ago
@tearlec If the Hive is not connected, and pressing the boiler controls 'fixes' it, I would suggest it is something connected with the boiler, rather than your router/internet connection.
ADDED; Can you post the current event log, please?
12 hours ago
12 hours ago
12 hours ago
Is there a timer on the boiler, or is it temperature controlled?
12 hours ago
12 hours ago
@tearlec wrote:
so will put up with it as I'm being driven crazy by this so will just run up to boiler if flashing orange repower Plusnet router
Fair enough, if you are happy doing that - me, I'd want the problem sorting once and for all.
