Flashing orange router
tearlec
Re: Flashing orange router
Just android have downloaded event file of router but can't attach to post here
Fixes: 139
You need to change the browser you are using to use 'desktop site'
For google chrome, with the reply window open, top right three dots, select Desktop site.
This should expose the paper clip icon below the reply box.
tearlec
Event file is massive anyway probably too b8g to download
tearlec
tearlec
Just tripped out to flashing orange wouldn't go to blue so powered off then on again to get blue again.Anyone else having issues?
Protech
Seasoned Pro
Fixes: 7
Post deleted
You can check out but you can never leave ( easily)
Fixes: 357
@tearlec Anything on the log?
tearlec
Yes wan disconnects advised to contact Plusnet they did line test and looks like external fault so they are contacting open reach again.Thanks everyone for advice and support.Openreach will come next week fingers crossed for the final visit
