Fibre broadband drop out
Fixes: 357
Re: Fibre broadband drop out
@Bridiebabes you said above 'it is an old-style master socket' If it is is an NTE 5C, it will be clearly marked as such - and have separate phone and broadband sockets.
EDIT to add - that is not a 5C.
Fixes: 558
@Bridiebabes if you don't use a phone,then for a start unplug that telephone cable.
I'd then unscrew the 3rd party faceplate and plug the filter directly  into the test socket on the Openreach box.
Bridiebabes
Then just leave the faceplate off?
Fixes: 558
Yes, it might not look neat but it may be better performing
Bridiebabes
Any news on when this engineer is booked?
Regards
RealAleMadrid
Fixes: 68
@Bridiebabes  If you have not heard anything I would assume that no engineer appointment has been booked.
How did you reply to the text from @MatthewWheeler in msg#16, not sure if a text reply is monitored?
A private message or a response to a ticket ( if there is one) in your member centre account would be better.
MatthewWheeler
Fixes: 503
Sorry to hear you've not had a confirmation @Bridiebabes
I've sent a e-mail and text confirming the appointment
Let us know how you get on
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
Bridiebabes
No problem thank you for your help
Will keep you informed how it goes
Thank you
Bridiebabes
Engineer has been and fitted a new MK4 box, he said it was my old box at fault, speeds are much better aswell pretty near double what I was getting previously.
Thank you
Fixes: 357
@Bridiebabes To be honest, I admit I was a little wary of your 'box'. Hope the replacement works and solves the issue.
Just for my information, can you post those two screenshots from your Hub again please - as they are currently?
Bridiebabes
Bridiebabes
The box is very old, thank you for all your help and advice
Bridiebabes
Wow just looking back at the pics from last week my downstream max was just over 9mb now with the new box my max is near 40mb. Amazing what a newer box can do
Fixes: 357
@Bridiebabes Thanks for those two screenshots -  your figures look much better now. The downstream SNR figure looks (to me) a  little low, but unless you notice any connection drops, ignore my concerns.
Bridiebabes
You jinxed it haha just had my first drop
