FTTC speed or lack there of.
- FTTC speed or lack there of.
Re: FTTC speed or lack there of.
29-03-2013 5:05 PM
As soon as he turns up he's going to be phoning you!
That's assuming he does turn up of course.
29-03-2013 6:19 PM
29-03-2013 8:41 PM
dick:quote
29-03-2013 8:58 PM
englishrick - Your speeds really slow down at peak times, but return to normal at off peak times?
finguz/pod000 - Your speeds are really slow 24/7?
It sounds like some kind of fibre fault for finguz/pod000 (which apparently is really hard to locate and only regional tech guys have the machines capable of finding these faults as they cost a small fortune) and some form of congestion issue for englishrick (I would take what an engineer says with a pinch of salt as its a different team that deal with the links/backhaul).
29-03-2013 10:59 PM
I have no idea if that could be related to the issues we're seeing of course, but it lists the Scarborough code.
30-03-2013 12:30 PM
I upgraded to PN fibre unlimited with provisioning completed on 4th March. My speeds, although slightly better than the dire 1Mb - 1.5Mb I was previously experiencing (the whole reason for going fibre) are absolutely rubbish! Guess what? I am also in Scarborough!!! My cabinet is on Burniston Road, so not just an issue with Dean Road! . And I've just done this test:
http://www.speedtest.net/result/2610535075.png
PN profile:
Phone exchange:
SCARBOROUGH
Estimated line speed:
36Mb (Accurate to within +/- 1Mbit) - Checked on 2013-02-18 22:21:10
Current line speed:
37 Mb
I've raised a ticket with PN.
30-03-2013 12:43 PM
30-03-2013 12:47 PM
Are those speeds wired or wireless - if wireless can you try wired
30-03-2013 1:45 PM
@pod000
I got a result of 11.24 download, 1.41 upload and 34.13 Ping Latency at 1.00am the other morning but generally I am getting similar to what I posted in that test
Was getting around 24Mb when I tested it in the first few days after going fibre but now it has dropped right down.
@Oldjim
This test was done from my main pc which is wired. I have laptops and tablets which are wireless that are also coming up with similar numbers
just tested again
http://www.speedtest.net/result/2610749935.png
30-03-2013 2:34 PM
Just checked your ticket on the account. Our testing system has automatically raised the issue with BT Wholesale, who are now requesting your availability for an engineer.
Please can you update the fault ticket on the account with three dates that you're available, an AM and PM slot on the same day counts as two different dates.
Let me know when you've done that, and I'll sort the rest out for you
Regards,
Matt
30-03-2013 3:46 PM
Thanks, I have updated the ticket with dates.
Regards
Stephanie
30-03-2013 3:57 PM
I'll update the ticket with the appointment slot once it's been confirmed
Enjoy the rest of your weekend!
Matt
30-03-2013 4:01 PM
Stephanie
02-04-2013 12:07 PM
Speedtest just done after engineer rewired socket:
Update on the Layer 2 problem would be appreciated as and when.
02-04-2013 2:01 PM
