FTTC speed or lack there of.
- FTTC speed or lack there of.
23-03-2013 7:23 PM
I phonedPlusnet and have done the connect straight to the modem and done the three speed tests which gave download speeds of 4---4--2Mbps with upload speeds hovering around the 15.3Mbps. Ihave included the last test I did..
This is a copy/paste of Plusnets speed profile .
Estimated line speed:
40Mb (Accurate to within +/- 1Mbit) - Checked on 2013-01-03 20:30:29
Current line speed:
77.4 Mb
The 40Mb is strange as I was on the wrong profile but after phoning Plusnet that was sorted in 48hrs and I was getting speeds of 75Mbps though it did fluctuate.
Re: FTTC speed or lack there of.
23-03-2013 8:04 PM
Do you know which exchange you are on? You can check here http://www.samknows.com/broadband/exchange_search
Can you try a speed test here: http://www.speedtest.net and share the result (image) here?
23-03-2013 8:12 PM
23-03-2013 8:18 PM
23-03-2013 8:33 PM
When I phoned plusnet the agent I spoke to kept impressing on me that if an engineer comes out and its down to my internal wiring I would be charged £60.
I am using Plusnets router with supplied cables and the openreach modem. I have connected two computers vis Ethernet directly to the modem and tested the speeds.
ping was constantly around 20ms and upload around 15.3Mbps but the download speed varied between 2.35Mbps and 7Mbps.
23-03-2013 8:39 PM
Do speeds return to normal outside the peak times?
23-03-2013 8:44 PM
23-03-2013 8:53 PM
23-03-2013 8:57 PM
23-03-2013 8:59 PM
23-03-2013 9:00 PM
@shalom doing kbdfaults now . thank you.
23-03-2013 9:06 PM
Same issues here on the same exchange
Apparently the exchange is showing as amber so we are suffering from congestion. Hopefully it will be sorted out by tuesday!
23-03-2013 9:15 PM
I`ve only had broadband with Plusnet for 14days and it took them 2 1/2 months to get it put in. Sheesh just call me Lucky
23-03-2013 9:18 PM
I was informed via my Plusnet fault ticket..
Quote Thank you for your continued patience. As per my message on the Forums, I have taken a look at the latest SVLAN report which is showing your exchange VP as 'Amber'. We are looking at a time period of 2 days for the VP to be increased.
23-03-2013 9:28 PM
Are those numbers in your area?
