FTTC slow browsing issue
- FTTC slow browsing issue
06-03-2014 4:35 PM
Recently had unlimited fibre installed and to begin with browsing speed was ok (perhaps slightly faster than adsl) with good download and upload speeds. Now whilst the down and up speeds have remained fine the browsing has become inconsistent, it quite often slows right down - sometimes pages have to be refreshed and there's even times when the page times out. It's getting to be really frustrating at times.
I'm connected by cable to BT HH5, predominantly on Mac though the issue is just the same on the Windows PC (also ethernet connected).
Any ideas on this?
Any ideas on this?
Message 1 of 4
(627 Views)
3 REPLIES 3
Re: FTTC slow browsing issue
06-03-2014 4:42 PM
I've had a look into this for you and can't see anything that immediately stands out.
Can you connect using the Windows PC and follow this guide: http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows...
This will help us rule out whether or not the router is causing any of the slowdowns.
Message 2 of 4
(387 Views)
06-03-2014 5:06 PM
Ok I have done that. At the moment it appears to be ok, but as I mentioned the problem can be intermittent so I guess I will need to just monitor it for now?
Previously I was using the Home Hub without the Openreach vdsl modem.
Message 3 of 4
(387 Views)
07-03-2014 12:28 PM
Let us know if the issue persists and we can investigate further for you.
Message 4 of 4
(387 Views)
