Line under BT Acceptable Range ?
mixxy
Where do I go from here, I still am affected by the ongoing DNS problems but have noticed my line falls short on downloads speed on the wholesale test page
Should I be asking for anything to be fixed ?
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Line under BT Acceptable Range ?
Hi mixxy,
I've had a look at your connection and can see that the connection rate is a little lower than I would have anticipated. Are you completing Speed Tests via an Ethernet Cable?
Chris Pettitt
Cloud Environments Engineer
mixxy
yeah was via cable
I have the guide to do a direct PPOE connection from windows then run the test ?
I can do that
If thats still low should i go though all the steps like changing the name in the router to the BT Test one  or could I do that from the manual PPOE connection
Plusnet Staff
Plusnet Staff
Fixes: 5
If you could try the PPPoE Test - that would be brilliant.
If the issue persists, I'd visit http://faults.plus.net so our Faults Team can take a look over things for you.
Chris Pettitt
mixxy
I have done the manual test and get the same result
I have reported the issue under faults
Plusnet Alumni (retired) LinnPlusnet
That's great, our Faults team will investigate further and should be back in touch with an update on the ticket in the next 48-72 hours.
