Email problems
jocky
Email problems
Is anyone having problems accessing email and Plusnet webmail. Service Status is showing as green, but I am unable to gain access and do not believe I have an issue with my Firewall. Thanks
26 REPLIES 26
spraxyt
Resting Legend
Fixes: 75
Re: Email problems
Email and webmail is OK for me.
David
Jake
Re: Email problems
Hi jocky, although telnet and Webmail seem fine our side, there's a few tickets I've seen where Webmail and email access is suddenly down. I'll get some examples so we can raise a problem.
Gel
Aspiring Champion
Fixes: 29
Re: Email problems
There was a problem earlier in sending e mails; seems to be cleared now.
(Was getting message that "relaying not permitted".
Peter_Vaughan
Re: Email problems
I've had delays picking up email via POP3 & IMAP over the past few days. Normally it is either very slow to connect to the server initially or it times out. A re-attempt normally then connects OK.
Seems OK at he moment though.
Anotherone
Champion
Fixes: 21
Re: Email problems
I've not had any problems POPing or access to Webmail currently.
hmburg52
Re: Email problems
Hi, I had a ticket raised this morning as I cannot connect to pop3 or webmail. My internet connection is fine apart from that but I cannot even ping webmail.plus.net as there is no connection.  They say it could be due to static IP's and will let me know, so there is a problem somewhere!
itsme
Re: Email problems
paulgul
Re: Email problems
I'm unable to connect to webmail, but pop3 is ok. Also most other PN portal pages are very slow loading. Had similar problms most of yesterday as well, cleared by the evening.
Paul
Anotherone
Champion
Fixes: 21
Re: Email problems
Silly question maybe (!), are you all logging into webmail here - https://webmail.plus.net/src/login.php and selecting the right server for your service?
Oldjim
Resting Legend
Fixes: 63
Re: Email problems
seems to a more general problem as I am getting errors
http://usertools.plus.net/status/archive/1241867208.htm
artmo
Aspiring Champion
Re: Email problems
I'm having a problem trying to collect my mail via Thunderbird  at present.  Each time I try to log in I'm told my password has failed and then get a box asking me to enter a new  password.
Tony_W
Re: Email problems
Also having password problems and then failures.
Chris
Legend
Fixes: 169
Re: Email problems
There is a P1 and service status out about this,  networks are trying to find the cause and updates will be sent out as we get them.
Anotherone
Champion
Fixes: 21
Re: Email problems
Sounds like it may be authentication issues then. I've just accessed webmail ok and popped ok. I don't know if it's gateway dependant, I'm on pcl-ag03. HTH.
