Dropping out..
patti
Dropping out..
For the last 10 days or so I have been losing my internet connection for a few minutes every day.. Can someone please check my connection and let me know what's going on please. Thank you.
9 REPLIES 9
Fixes: 387
Re: Dropping out..
@patti Thought I was correct - you reported a similar issue 11 months ago, where I made a suggestion, but we never heard anything back.
patti
Re: Dropping out..
Hi John, Yes there was a problem a while a go but it was rectified. and now its dropping my connection. Any ideas?
started again.
My apologies for not getting back to you I thouht t had all be done with.
Fixes: 387
Re: Dropping out..
@patti It appears you have a similar issue to last year - they can reoccur. Follow https://www.plus.net/help/report-a-problem/
patti
Re: Dropping out..
Thank you John for your assistance. If it keeps on happening I will get in touch with Plusnet.
Patti
dave
Fixes: 21
Re: Dropping out..
Hi @patti I think I've found a problem that's affecting your broadband, I've got someone working on it now so hopefully be fixed shortly.
Dave Tomlinson
Plusnet Technology
dave
Fixes: 21
Re: Dropping out..
Should be fixed now.
Dave Tomlinson
Plusnet Technology
patti
Re: Dropping out..
HI Dave,
Sorry. I've just seen this .. It was fine until the weekend..  Saturday and Sunday it kept dropping out and today for a short while, Can you have another look and see what may be causing this please? Appreciate your help.
Thank you
Patti
Tina11192
Fixes: 18
Re: Dropping out..
@patti Thank you for getting back in touch with us, I'm sorry to hear the issue is still ongoing.
I have tested your line and found there's a fault with the network, which is affecting your service. I have now raised this with Openreach and I have also emailed you from the account, please allow up to 2 working days for this to be addressed.
I hope this helps, please let me know if there's anything else in the meantime.
Cri Ignatti
patti
Re: Dropping out..
Thanks Tina.
Ive received a text message from Openreach and will await further communication.
