Disconnects - Help Please
Fixes: 387
Re: Slow as treacle
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
superuser
Re: Slow as treacle
Thank you so much for your reply
I do not have a phone and the router is Draytek
My line is plagued with issues. The line is patched to all heck heading to the Cab
It just needs sorting
Fixes: 387
Re: Slow as treacle
Fair enough if you have a dodgy line, and agree it needs sorting, but I can't honestly see anything in that screenshot which could account for the behaviour, apart from possibly the upstream error figures, which are extremely high.
superuser
Re: Slow as treacle
If an engineer can be arranged please. Because this is like slower than dialup
Thank you
Fixes: 387
Re: Slow as treacle
As I said, the speed to your router is perfect, but the u/s error rates are horrendous. An engineer visit may solve it, but may not.
What does a speedtest show at the moment, preferably the https://speedtest.btwholesale.com/ one, including the 'Additional Diagnostic' detail?
superuser
Re: Slow as treacle
It's confusing because it's different to speedtest.net
And it seems to imply a faster download speed, that actually has little reflection to what is happening on all my devices.
I'm basically crawling along
superuser
Re: Slow as treacle
And again with speedtest.net
Is probably a true reflection of how slow it is
csmith94
Fixes: 31
Re: Slow as treacle
That's quite a big difference between them both @superuser.
Was one of the tests done on a wired connection and the other on wireless? Were both tests also done on the same device or different one?
If a wired speed test hasn't been done, would you be able to do this and send across the results please?
 Curtis Smith
superuser
Re: Slow as treacle
It was all wireless. I know, wired is better, but I'm right next to the router.
Any case
I pulled the plug on everything. Let it reconnect and it's back to speed
csmith94
Fixes: 31
Re: Slow as treacle
That's good then, least it's back to normal now!
 Curtis Smith
superuser
Re: Slow as treacle
It is
superuser
Re: Slow as treacle
Line dropped again this evening around 9.30PM
Happens once or twice a day
superuser
Re: Slow as treacle
And again around 4.30AM
Thatwilllldo12
Re: Slow as treacle
 Huh. I've kept an eye on this thread as I've been plagued with similar WAN disconnects since Nov 22. Your recent listed disconnects times seem very similar to what mine are now 4:30 am and 20:30.
superuser
Re: Slow as treacle
Now it's sync has dropped off a bit too
 Connected : Down Stream : 68484Kbps / Up Stream : 12713Kbps
