DNS weirdness
- DNS weirdness
Re: DNS weirdness
16-07-2009 11:53 PM
What is going on ?!
Re: DNS weirdness
17-07-2009 9:46 AM
Quote from: adriantribe Is there are any other test I should do when the lookup ability is down that would provide
PlusNet techies with any helpful data for diagnosing and thus fixing the problem?
Yes, see here. In particular the IPCONFIG and NSLOOKUP commands.
Quote Incidentally, can anyone explain why when I try to do an ipconfig /flushdns
on my daughter's Windows Vista laptop, I get the message "The requested
operation requires elevation"?
Yes, it will be something to do with User Access Control or her permissions. You could either try disabling UAC or alternatively click start, type 'cmd' in the search field but *don't* press enter. Instead right-click 'cmd.exe/ in the program list above and try selecting the 'Run as administrator' option.
BTW, are you still having problems too?
Re: DNS weirdness
17-07-2009 7:00 PM
traceroute to 212.159.6.10 (212.159.6.10), 64 hops max, 40 byte packets
1 192.168.0.1 (192.168.0.1) 1.686 ms 11.055 ms 11.055 ms
2 lo0.plusnet.thn-ag2.plus.net (195.166.128.93) 31.773 ms * 79.191 ms
3 vl604.thn-gw1.plus.net (84.92.4.169) 26.166 ms 29.630 ms 25.798 ms
4 ae0-102.ptn-gw01.plus.net (212.159.1.53) 97.781 ms 153.601 ms 197.548 ms
5 * * *
6 * * ae0-102.ptn-gw01.plus.net (212.159.1.53) 26.356 ms !X
7 * * *
8 * * *
9 * * *
10 * * *
traceroute to 212.159.6.9 (212.159.6.9), 64 hops max, 40 byte packets
1 * 192.168.0.1 (192.168.0.1) 8.074 ms 1.020 ms
2 lo0.plusnet.thn-ag2.plus.net (195.166.128.93) 26.884 ms 26.701 ms 137.832 ms
3 vl604.thn-gw1.plus.net (84.92.4.169) 35.721 ms 45.878 ms 81.056 ms
4 ae0-102.ptn-gw01.plus.net (212.159.1.53) 27.576 ms 27.196 ms 25.824 ms
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
maybe it's just something to do with me being on 21CN trial - and on a mac? I dunno…
Re: DNS weirdness
17-07-2009 8:57 PM
Worse than ever today - very difficult even to access plus net member center.(!)
ipconfig
Host Name . . . . . . . . . . . . : Mick
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek RTL8139/810x Family Fast Ethernet
NIC
Physical Address. . . . . . . . . : 00-01-2E-10-61-93
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::3d18:1d6e:6c4c:f752%8(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.2(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 17 July 2009 19:18:11
Lease Expires . . . . . . . . . . : 20 July 2009 19:18:11
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 134218030
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-0F-48-B4-4D-00-01-2E-10-61-93
DNS Servers . . . . . . . . . . . : 212.159.13.50
212.159.13.49
NetBIOS over Tcpip. . . . . . . . : Enabled
C:\>nslookup bbc.co.uk 212.159.13.50
DNS request timed out.
timeout was 2 seconds.
Server: UnKnown
Address: 212.159.13.50
*** Request to UnKnown timed-out
C:\>nslookup bbc.co.uk 212.159.13.49
Server: UnKnown
Address: 212.159.13.49
Server: pth-cdns01.plus.net
Non-authoritative answer:
Address: 212.58.224.138
Server: pth-cdns02.plus.net
*** Request to pth-cdns02.plus.net timed-out
I repeated this and most times had the same result
Mick
Re: DNS weirdness
17-07-2009 9:55 PM
Tried this again later to check with this result
C:\>nslookup microsoft.com 212.159.13.49
Addresses: 207.46.197.32
207.46.232.182
C:\>nslookup microsoft.com 212.159.13.50
Addresses: 207.46.232.182
207.46.197.32
Lets see what tomorrow brings?
Re: DNS weirdness
17-07-2009 11:37 PM
Thank you for your reply.
Just had another period of no lookup ability, during which time I did an ipconfig /all. The relevant part
of the results showed:
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . : home
Description . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Network Connection
Physical Address. . . . . . . . . : 00-1F-3C-97-78-99
Dhcp Enabled. . . . . . . . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.2
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
Lease Obtained. . . . . . . . . . : 17 July 2009 22:35:47
Lease Expires . . . . . . . . . . : 18 July 2009 22:35:47
So I checked on the router instead, which showed that the DNS servers were set to:
Primary DNS Server 212.159.6.10
Secondary DNS Server 212.159.6.9
Before I was able to do an nslookup against one of these my full connectivity was
restored, so I don't know the outcome of that particular test.
I'll check again tomorrow, but in summary, the problems are still continuing.
Re: DNS weirdness
18-07-2009 11:10 AM
Instructions here http://www.mediacollege.com/computer/network/dns.html
Re: DNS weirdness
18-07-2009 3:19 PM
Before I changed to Treewalk I explicitly set the DNS servers on the PC to the PN servers - I found that over time the router got clogged up and needed rebooting. After I stopped using the DNS on the router it didn't need the periodic reboots.
Re: DNS weirdness
18-07-2009 4:37 PM
DHCPv6 IAID . . . . . . . . . . . : 184556109
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-0F-2A-81-41-00-1A-4D-59-68-29
DNS Servers . . . . . . . . . . . : 208.67.222.222
208.67.220.220
Re: DNS weirdness
18-07-2009 8:19 PM
Re: DNS weirdness
18-07-2009 8:26 PM
Re: DNS weirdness
18-07-2009 11:21 PM
Description . . . . . . . . . . . : Intel(R) PRO/1000 MT Network Connection
Physical Address. . . . . . . . . : 00-0F-1F-9B-02-53
IP Address. . . . . . . . . . . . : 192.168.0.9
DNS Servers . . . . . . . . . . . : 192.168.0.1
Lease Obtained. . . . . . . . . . : 18 July 2009 23:15:04
Lease Expires . . . . . . . . . . : 19 July 2009 23:15:04
Are you using standard Netgear firmware?
Re: DNS weirdness
18-07-2009 11:30 PM
Re: DNS weirdness
19-07-2009 3:39 PM
What I don't understand is that during the last problem period I
did an nslookup on, for example, the bbc web site, specifying
the PN DNS server 212.159.6.9 and actually got a result - it was
abe to lookup the name and return the IP address.
However, my web browser was still not able to find the site.
So basically I've given up on this issue being properly resolved.
I have for now hard-coded the openDNS name servers into my
router and this afternoon everything is working absolutely fine.
If this is likely to cause me problems in the long term then perhaps
someone would let me know and explain.
Re: DNS weirdness
19-07-2009 4:28 PM
Rather than hardcoding the DNS settings into your router, have you tried hardcoding our DNS settings on the TCP/IP configuration of your network card on your computer?
I think I've seen 2 complaints about DNS this weekend. If there were more I would have escalated out to our networks team, buit it's not sounding like a generic problem.
