DLM Reset
FIXED- Subscribe to RSS Feed
- Re: DLM Reset
24-08-2022 8:59 PM
Hello,
Is it still possible to request a DLM reset via the forum? If so, I would appreciate if this could be arranged.
My line has been banded at 20000kbps download for ages and as far as I can tell, there doesn't seem to be anything wrong with the line. The BT checker says I should get 21.4 - 32.8Mbps and I remember getting about 26Mbps previously, without interleaving. I've got the modem plugged into the test socket and there are no extensions or phones plugged in.
I've been using dslstats for a while and the connection is up for days/weeks at a time and the daily ES is low too so I don't know why the banding and interleaving is not being removed.
Thanks,
Steve
Fixed! Go to the fix.
Re: DLM Reset
29-08-2022 4:25 PM
Re: DLM Reset
29-08-2022 7:38 PM
Hello Adam,
Have PM'ed you my username as requested.
Cheers,
Steve
Re: DLM Reset
01-09-2022 8:40 PM
Hello Adam,
Have you had chance to organise the reset?
Cheers,
Steve
06-09-2022 7:26 PM
Hiya Steve,
We’re quite chocka right now, so it’s taking a little longer than I’d usually like to get back to customers and I'm sorry about that.
I have requested this for and it take about 30 minutes to go through.
Let us know if you need any further help at that point ![]()
Re: DLM Reset
07-09-2022 7:29 PM
Hello SammyM,
That has worked a treat - am back up to 24Mbps and no interleave.
Will see how long it lasts...
Thank you for your help.
Steve
Re: DLM Reset
07-09-2022 7:38 PM
