DLM Reset
steve_v
DLM Reset
Hello,
Is it still possible to request a DLM reset via the forum? If so, I would appreciate if this could be arranged.
My line has been banded at 20000kbps download for ages and as far as I can tell, there doesn't seem to be anything wrong with the line. The BT checker says I should get 21.4 - 32.8Mbps and I remember getting about 26Mbps previously, without interleaving. I've got the modem plugged into the test socket and there are no extensions or phones plugged in.
I've been using dslstats for a while and the connection is up for days/weeks at a time and the daily ES is low too so I don't know why the banding and interleaving is not being removed.
Thanks,
Steve
6 REPLIES 6
adamwalker
Fixes: 223
Re: DLM Reset
Hi Steve, sure I'll take a look at that for you. Can you send me a PM with your username please? - Adam
 Adam Walker
steve_v
Re: DLM Reset
Hello Adam,
Have PM'ed you my username as requested.
Cheers,
Steve
steve_v
Re: DLM Reset
Hello Adam,
Have you had chance to organise the reset?
Cheers,
Steve
SammyM
Fixes: 101
Re: DLM Reset
Hiya Steve,
We’re quite chocka right now, so it’s taking a little longer than I’d usually like to get back to customers and I'm sorry about that.
I have requested this for and it take about 30 minutes to go through.
Let us know if you need any further help at that point Smiley
 Sammy M - Sheffield Team
steve_v
Re: DLM Reset
Hello SammyM,
That has worked a treat - am back up to 24Mbps and no interleave.
Will see how long it lasts...
Thank you for your help.
Steve
SammyM
Fixes: 101
Re: DLM Reset
Fabtastic Steve, well chuffed it's sorted.
Let me know if you need any further help Smiley
