D-Link DSL-2640B?
- Re: D-Link DSL-2640B?
- « Previous
- 1
- 2
- Next »
04-09-2008 3:48 PM
It's very abnormal.
What happens after a reboot?
Message 16 of 17
(186 Views)
04-09-2008 4:03 PM
Well iv just rebooted and iv synced back to 2432 however my SNR margin is all over the place and not static, its telling me 16dB atm then a few secounds later will change 10dB then 14 and so on, its very eratic, earlier when i was using my netgear i was syncing at 3.6mb then it shot down to 160kbps and i could hear some sort of dial tone on my line, then the postman gave me the new router, plugged that in and everything no noise on the line, but lower sync then it droped to 700 and now its back to 2000+.
Quite odd really, i dont actually disconnect from the internet, just my sync and SNR margin change alot.
Also these drops in sync play havoc with my IP profile, im now back on 135k
What do you think is happeneing?
Message 17 of 17
(186 Views)
- « Previous
- 1
- 2
- Next »
