Current sped drop - result of flooding?
- Re: Current sped drop - result of flooding?
- « Previous
- 1
- 2
- Next »
28-11-2012 11:21 PM
Errors:
Errors at 17:48 0 / 13.180.391
Errors at 23:20 0 / 13.180.535
I think we can say that the errors have stopped. I'm happy for a line reset whenever you fine bods at PN think it's a good plan to do so.
S
S
Message 16 of 24
(443 Views)
29-11-2012 10:47 AM
You had a disconnection just before one this morning, was this caused by you?
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13541859335813.png"/><div style="clear:both;"></div>
Still seeing a few errors on your line at the moment so I'd suggest monitoring this over another day.
Message 17 of 24
(443 Views)
29-11-2012 10:52 AM
Nope. Nothing my end. Didn't check the errors this morning. I'll do it again this evening when I get back.
Message 18 of 24
(443 Views)
29-11-2012 11:09 AM
SNR seems quite stable (and strangely doesn't seem like it disconnected) - I'll take a look at the router stats this evening to see what that says for the amount of time the conneciton's been up.
Message 19 of 24
(443 Views)
29-11-2012 9:29 PM
Latest stats. Reconnected this afternoon - no idea why but back at normal sync speeds. Can I have an IP profile reset please because I'm still down at 1.5Mbps:
Uptime: 0 days, 5:53:29
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1.036 / 5.490
Data Transferred (Sent/Received) [GB/MB]: 1,99 / 751,06
Output Power (Up/Down) [dBm]: 12,8 / 0,0
Line Attenuation (Up/Down) [dB]: 26,3 / 50,0
SN Margin (Up/Down) [dB]: 4,8 / 7,8
Loss of Framing (Local/Remote): 26 / 0
Loss of Signal (Local/Remote): 3 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 41.887 / 2
FEC Errors (Up/Down): 380 / 16.925
CRC Errors (Up/Down): 32 / 125
HEC Errors (Up/Down): 20 / 1.958
Message 20 of 24
(443 Views)
29-11-2012 9:39 PM
I assume you mean the Plusnet profile as the IP profile should have increased immediately - you can check that with the BT speed test
Message 21 of 24
(443 Views)
29-11-2012 9:42 PM
Yes, the one that Plusnet has control over. I'm syncing at ~5Mb but max download speed from BT speedtester is only 1.3
Message 22 of 24
(443 Views)
30-11-2012 10:17 AM
I've changed your speed profile to match your sync speed, so you'll see an increase in speeds.
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image1354269970554.png"/>
The errors have reduced on your line too, it certainly looks like an improvement.
Did you do any of the disconnections that are in the graph? One of them is a speed profile change from yesterday.
Message 23 of 24
(443 Views)
30-11-2012 11:17 AM
No, I haven't done anything at my end. Not sure what the disconnections are, but the sync speed has been stable since so I guess that I'll just live with the disconnections (I haven't noticed any problems with it though). Thanks for changing the speed profile.
Message 24 of 24
(443 Views)
- « Previous
- 1
- 2
- Next »
