Connection keeps dropping
ghamilton123
Re: Connection keeps dropping
Actually yesterday it went down twice?
01:14:49, 15 Oct. DSL Link Down: duration was 128654 seconds
01:27:44, 15 Oct. DSL Link Down: duration was 687 seconds
01:46:00, 16 Oct. DSL Link Down: duration was 87411 seconds
Fixes: 386
Just been looking a the 'Error_no_carrier' message. Have the engineers actually  checked your connections on the OpenReach lines - i.e. from your drop-wire back to the fibre cab?
ghamilton123
Nope, like I said the only thing they checked was the connection going from the mastersocket to the router
Fixes: 386
OK. Just that looking at one or two reports that contain that fault report, it seems to indicate connection issues (loose/corroded)
Is yours an overhead or underground link?
ghamilton123
I actually have no clue how it comes in, had a look around and I believe its coming in from a flat in the middle under the ground
Fixes: 386
So no overhead cables then? A pity, as they are easier to check than underground connections. All I can suggest at the moment then is see how the new Hub performs, but I don't hold out much hope.
ghamilton123
Really doubt its going to help, see someone on BT forums say they had same issue, and the faceplate got replaced and it solved, so I am assuming the issue would be with the cable, we're expecting fibre to the pole by late November, but it'd be the waiting time for pole to the flat block, surely I'd be able to also claim some compensation for the issues this is causing no?
Fixes: 386
Just a thought based the comment about the replaced faceplate in your post above - which master socket have you got - a 5C with a Mk.4 faceplate, or one of the earlier ones? Might just be an idea to plug direct into the test socket, using a dangly filter?
ghamilton123
I'm already using the test socket, but its a 5c
Fixes: 386
Thanks - that points fairly clearly to a fault upstream of your connection then. The new Hub will be of no use whatsoever.
ghamilton123
Not entirely sure on what to do then, since PN probably wont care until I've tested the new router.
Fixes: 386
All you can do is test the new Hub, but I  sincerely doubt it will solve the issue. I'm sure it is a problem upstream of your Master socket.
ghamilton123
Guess its a week long waiting game, then however long it takes for it to disconnect before I can report it to PN, surely I'd be entitled to some sort of compensation due to the issues caused by the intermittent connection, I've just started a online uni course and work from home so the issues with the connection is a big issue, I can't even get reliable 4g(9mbps/2up at most) where I am so I have to rely on ORs network, and like I said before we're expecting fibre going to a pole by the end of November, so it'll be a bit of a wait if I have to wait until FTTP
Fixes: 386
I don't know about the compensation angle, to be honest, but from what I have read on here, this is only payable if you have a complete loss of connection for longer than 3 days after initially reporting an issue.
ghamilton123
Seems like a bit of a joke in my opinion, had to shape my day around the friday engineer time, and then having to call repeatedly, especially with the engineer not even batting a eye at the logs etc
