Connection keeps dropping
ghamilton123
Connection keeps dropping, seems to be seemingly random aswell
17:44:12, 12 Oct. PPP: Sending PADI
17:44:07, 12 Oct. PPP: Sending PADI
17:44:02, 12 Oct. PPP: Sending PADI
17:43:59, 12 Oct. DSL Link Up: Down Rate=79999kbps, Up Rate=20000kbps; SNR Margin Down=12.9dB, Up=8.4dB
17:43:57, 12 Oct. PPP: Sending PADI
17:43:52, 12 Oct. PPP: Starting PPP daemon
17:43:51, 12 Oct. WAN Auto-sensing detected port DSL WAN
17:42:24, 12 Oct. Receive a DHCP request
17:42:24, 12 Oct. SIP WAN DOWN
17:42:23, 12 Oct. WAN Sensing Auto sensing Complete, interface selected
17:42:23, 12 Oct. WAN Sensing Auto sensing Running
17:42:22, 12 Oct. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
17:42:21, 12 Oct. PPP: Stopped PPP daemon(0,1,5)
17:42:21, 12 Oct. PPP LCP Send Termination Request (User request)
17:42:21, 12 Oct. PPP: IPCP down
17:42:21, 12 Oct. PPP: LCP down
17:42:21, 12 Oct. DSL Link Down: duration was 338725 seconds
Been happening randomly throughout the month and a half
106 REPLIES 106
Fixes: 388
Re: Connection keeps dropping
@ghamilton123
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
ghamilton123
Had a engineer out today, they're just replacing the router, I have a family member that works with Openreach thinking its been a dodgy extension install job, due to the master socket looking like its been moved from the living room into the hall, the disconnects are inconsistent, I can go a week without a disconnect, then maybe 2 days, I guess we just wait and see once the new router arrives, but I feel like if it was a faulty router, the disconnects would happen more frequently?
Fixes: 388
Oh dear - the usual 'blame the Hub, because I can't be bothered to do my job' response we hear all too often. I would be extremely amazed if a new Hub solves this.
ghamilton123
A bit surprised myself, he wasn't even in for 10 minutes and was out after "ordering a new hub", I told him what I suspected, Plusnet on the phone also noted what I told them about the master socket extension, but still went and blamed the hub, realistically as well I've only been moved in for not even 2 months, so I would doubt that a new hub has developed a fault that fast, unless its came like that from the factory, all I know is he ran a line test which showed nothing, then was like "new hub it is"
Fixes: 388
Be prepared to re-report the issue.
ghamilton123
Been told to verify that hes actually ordered a new router by calling them, the email I received basically said the fault was a master socket repair, and he didn't even look at it should I bring that up aswell?
Fixes: 388
I would give PN a call and actually reschedule a proper engineer. Thinking about it, OR engineers don't usually 'order a replacement Hub, although they may suggest one is supplied, in their report.
If it was claimed to be a socket repair, and he didn't even look at said socket, then a complaint is in order.
@jab1
I'm sort of wondering if it was someone from QubeGB rather than Openreach.
Fixes: 388
@Dan_the_Van Possible - but we would need the OP to confirm.
ghamilton123
Not entirely too sure, had a text saying openreach, called PN they said the tickets on a monitoring period on the scale of the dropouts and they cant see the router being ordered
Fixes: 388
Looking back at your original post, I would expect it to be an OR engineer, but if he did as little as you say, he was not very good (to be polite), and I would still push for a second one.
Out of interest, how has the connection behaved since  your original post? Do you have a Hub1 or Hub2?
ghamilton123
I believe its a Hub2, I only moved in and joined plusnet end of august from the 1st post, its been intermittent since its been activated, theres been no disconnects yet, but it can go a week+ without disconnecting then it disconnects
Fixes: 388
OK. It will be a Hub2. Are you able to export the log in .csv format, and post it here?
ghamilton123
Heres the log I got last night after it disconnected
