Connection dropping
adamwalker
Fixes: 223
Re: Connection dropping
No problem at all! I hope that gets everything sorted out for you. I'll make sure we follow things up with you as soon as we can after the visit.
 Adam Walker
patti
Hi Adam,
Engineer just left and when I asked him what the problem was,  he said everything seemed fine. He just said keep an eye on it.
Regards
Patti
patti
Hi Adam,
Connection just dropped again for about a minute..
Just to let you know.
Can you check my landline again please.
Patti
Fixes: 390
@patti The engineer was wrong - I suspect you need him back.
patti
Hi John,
You you explain further please?
Patti
Fixes: 390
@patti If you are still suffering drops, less than 24hrs after an engineer says 'it all looks fine' then there is still something wrong. Any idea what the engineer did?
patti
John,
To be honest, he was here for about 20 minutes or so then he left, saying he was off to check the connection, he was gone for about 40 minutes.. when he left I asked him what was wrong and he really didn't seem to know I did mention that Plusnet had said there was a fault on the landline but he didin't answer me.. (not the most talkative person I ever met).. he said he had replaced something but I didn't hear him properly. So what do I do now?
Patti
Fixes: 390
You could report the problem again, but I suspect the answer would be 'it's only happened once since the engineer visit, just keep your eyes on it'.
A couple of questions: which hub do you have, which master socket, do you want further help, and (don't take offence) how technical are you?
patti
@jab1
Just dropped again this time longer.. I just called Plusnet and explained the issues. It was mentioned it might be a REIN issue as per the Engineer's report..  (it only happens in the afternoon) It is being left until Monday and then, if it's still dropping the connection it will be reported to Openreach and another Engineer will come and have a look. I have been with Plusnet for years and although there have been drops they have been fixed. Fingers crossed it might stabilise itself.
There's nothing else I can do,
Thanks John,
Patti.
James30
Fixes: 32
@patti -  Cheers for calling, I've handed the issue over to get picked up on Monday for you as I'm not in.
James - Plusnet Sheffield
patti
Hi James,
Thanks for your help. Fingers crossed.
Patti
Fixes: 390
OK @patti , I'll take this off my 'watch list' and leave it to Plusnet.
patti
Thanks for your help John, much appreciated.
Patti
SammyM
Fixes: 101
Thanks for your patience @patti. you're a star Smiley
I have passed the issue back to our supplier as their testing has not found anything through automation and we are most likely going to need to book an engineer. We will keep you updated!! Smiley
 Sammy M - Sheffield Team
patti
@SammyM
Thank you Sammy.
My speeds are very poor at the moment.
Patti
