Connection dropping
patti
Connection dropping
Hi, Anyone else experiencing their connection dropping out intermittently since yesterday? I have reset it but wondering if there is a problem at Plusnet?
29 REPLIES 29
Fixes: 387
Re: Connection dropping
@patti Are you actually on Full Fibre (FTTP) or fibre to the cabinet (FTTC)? What happens when the connection 'drops out' - does the router light change?
patti
Hi John,
Fibre to the Cabinet .. When the connection drops the light turns orange. It has been only in the afternoon for the last 2 days around 2 to 4  p.m happens about 3/4 times and then it's ok?
Fixes: 387
OK, thanks for confirming you are on FTTC, as I thought.You obviously have a problem. my first suggestion is to follow the text below, but if they come back and say you haven't a problem, as it says at the end of that - come back and let us know, there are further options we can explore.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
Mav
Fixes: 518
Moderator's note(s):
Thread moved from Full Fibre to Broadband.
Forum Moderator and Customer
patti
Hi John and thank you for your help.
I tested my phone line and it's silent.
The drop has been usually between 2 and 4 pm so I'll keep and eye on it today and see what happens. Fingers crossed it will have resolved itself. If not, then I will us the link you provided to report a fault.
 Again, thank you.
Patti
Fixes: 387
OK - let us know what response you get.
James30
Fixes: 32
@patti Hiya, I tried to give you a ring about the fault as I'm testing the connect here and it's failing and need to do a few checks inside your property. Feel free to send me some pictures on here or on a DM of the front and back of your router so I can see what we're dealing with. Cheers
James - Plusnet Sheffield
patti
Hi James,
Thanks for calling.
It seems to be ok for the last couple of days, no drops.
I have the Router situated on a corner unit next to the line box. There is nothing electrical near it to interfere with the signal.
The camera on my phone isn't working so I cant take any pics.
I upgraded to a new Router approx 2 years ago.. sometimes the connection drops but not very often at all and only for maybe a few minutes..
Not sure if this info has helped any but I'm around on Tuesday if you want to call me.
Thanks for your helkp.
Patti
adamwalker
Fixes: 223
Hi there Patti, just to check the things we normally do when we go through visual checks on your set up, does the phone socket your router plugs into have two connections? (i.e one for a router and a phone) or just a single socket? Also are you using the Plusnet router we supplied and do you have any devices connected into the LAN ports on the back?
Adam
 Adam Walker
patti
Hi Adam,
Thanks for getting back to me.
To confirm, there are 2 connections on the phone socket. I am using the router you provided and there is also a Philips Hue bridge. The connection dropped again about 10 minutes ago for literally 2 minutes. What could it be?
Patti
adamwalker
Fixes: 223
Not a problem, I've just been running a more detailed line test and that shows there's a physical fault with the phone line so we'll just need to arrange an engineer visit with you next.
Can you let me know your availability in these times please?
Monday to Friday
AM = 08:00 to 13:00
PM = 13:00 to 18:00
 Adam Walker
patti
Hi Adam,
Thanks for your email.
Just to confirm. I'm available a.m from this coming Friday and next week onwards.
Regards
Patti
adamwalker
Fixes: 223
Thanks Patti, I've just sorted that out for you and added an update to the ticket. - Adam
 Adam Walker
patti
Great, thanks Adam.
